What factors make loader specs so close - yet so different?
   / What factors make loader specs so close - yet so different? #1
jim_wilson
Veteran Member
Northeast MA
Kubota B3200 w/ BH77 & 12", 18" & 24" buckets, Kubota B50 SSQA w/ 54" & 60" buckets, LandPride FDR1660, Artillian Fork frame, Extreme 3pt rake, Concrete Mixer, MyTractorTools grapple adapter
I've been comparing a Kubota B3300 and L3800 on their specs (trying to make a purchase decision) - and their is something that is bugging me - because it sort of doesn't make any sense.
When I look at the loader specs for the two tractors I see:
Lift capacity (pivot pin) :
B3300SU (LA504) = 1065
L3800 (LA524) = 1131 (max ht.)
Lift Capacity: (forward) :
B3300SU (LA504) = (19.7in) 730
L3800 (LA524) = (500mm) 855 (max ht.)
Breakout Force (pivot pin):
B3300SU (LA504) = 2474
L3800 (LA524) = 2462
Breakout Force (forward):
B3300SU (LA504) = (19.7 in) 1737
L3800 (LA524) = 1874
The breakout force at the pivot pin on the two loaders is very close. Yet - the forward numbers on breakout force are a lot different. The lift capacity at the pivot pin on both are close - but they are farther apart on the forward number.
Is this a leverage thing? Or is the cylinder diameter affecting some numbers more drastically than others?
   / What factors make loader specs so close - yet so different? #2
My guess would be leverage or mounting location of the curl cylinders in relation to the bucket pivot point.
Hydraulic cylinders provide a constant force at a constant pressure.
   / What factors make loader specs so close - yet so different? #3
I am think it all relates to the geometry of the boom cylinders. The relation ship to their mount position on the mast and boom and the distance from the boom pivot pin to the bucket pivot pin.
My definition of breakout force is the bucket lift force at the ground level using the boom lift cylinders.
Bucket rollback force would be using the curl cylinders.
   / What factors make loader specs so close - yet so different? #4
Excerpt:
Here's what Cat says the SAE (Society of Automotive Engineers) definition is for wheel loaders:
Breakout force is the maximum sustained vertical upward force exterted 100mm (4" behind the tip of the bucket cutting edge and achieved through the ability to lift and/or rollback about the specified pivot point under the following conditions:
Here is what Case says about the 1845C
The maximum rated operating load of the Case 1845C is 1,750 lbs., and the tipping load is 3,545 lbs. The breakout force of the bucket and lift arm is the maximum force that the machine is able to exert. The breakout force of the lift cylinder is 3,450 lbs., and the breakout force of the bucket cylinder is 4,690 lbs. With the bucket loaded it takes 4.3 seconds to raise the lift, 2.9 seconds to lower it, 2 seconds to dump the bucket and 1.4 seconds to roll back the bucket.
More breakway/breakout force is achieved with the combined power of the loader lift and bucket (crowd-dump-fill) cylinders. The combination of a tractor/loader's weight, hydraulic lift capacity, loader design, traction all are important ingredients to determine how much "breakout" force the equipment may develop.
2007 JOHN DEERE 624J WHEEL LOADER (A51406)
2007 JOHN DEERE...
2016 E-Z Beever M12R Towable Brush Chipper (A51691)
2016 E-Z Beever...
1999 CLEMENT END DUMP (A53843)
1999 CLEMENT END...
2019 ExMark S-Series 72in Zero Turn Mower (A51692)
2019 ExMark...
2013 Chevrolet Silverado 3500HD Enclosed Service Truck (A52377)
2013 Chevrolet...
(INOP) JOHN DEERE TS GATOR (A51247)
(INOP) JOHN DEERE...
