Buying Advice What excavator do i buy
   / What excavator do i buy #1
csharpe5097
NY
Kubota L4240
My choices are a 2007 KX 91-3 with 1800 hrs for 29,500 or a 2006 KX 91-3 with 2900 hrs for 16,500. Its for personal use on my land.
   / What excavator do i buy #2
thats a life time of use differance for personal use. I would keep looking a low hr kx91 or 121 I just looked a 121 with 400hrs and was afraid to offer 30 as I think he would have sold it. About week later it was sold so???
   / What excavator do i buy #4
I would agree with Sunshine if you can find one in time however I would go with the higher hours and half the price since this is personal use and assuming that they are otherwise similar in condition and upkeep. That is a significant difference in dollars and not that meaningful in hours if all else is the same.
   / What excavator do i buy #5
Prices vary all over the country, and what may be high in one area might be normal in another. Assuming that the prices are good in your area, I wouldn't even think about it. The 2006 machine for almost half the price is by far the better deal if everything else is the same. 3,000 hours is well broke in, but only half way to being tired, and probably a third of the way to being worn out if it's been maintained.
Home use means you wont use it all the time like commercial use, so it's probably going to get used weekends? evenings? maybe for a short period of time quite a bit. But it will also sit for long periods of time, so you won't add many hours to it.
Eddie
   / What excavator do i buy #6
This did not meet reserve on E-bay today, high bid was insult at $24,700. 2'nd time it was listed. If you could get it for under 30K, you would be stealing it.
I have same weight machine, but much much older.
Used 2007 TAKEUCHI: An item that has been used previously. The item may have some signs of cosmetic wear, but is fully ... Read more
Excavator Type: Compact
Model Year: 2007 Make: TAKEUCHI
Hours: 3400 Model: TB175 18,000lbs or 2 x the weight of a KX-91
Serial Number: 17513784
2007 TAKEUCHI TB175, WITH BLADE, FULL CAB, A/C, HEAT. HIGH FLOW 3RD VALVE, HYDRAULIC THUMB AND HYDRAULIC QUICK DISCONNECT, RUBBER TRACKS, 3400 HOURS, ONE OWNER, ORIGINAL PAINT, EXCELLENT SHAPE. S/N: 17513784. CALL 603-641-8608 FOR MORE INFORMATION. ITEM IS SOLD "AS IS, AS SOLD" NO WARRANTIES IMPLIED OR EXPRESSED. ITEM IS FOR SALE LOCALLY, SELLER HAS THE RIGHT TO END AUCTION EARLY IF ITEM IS SOLD BEFORE AUCTION END. DEPOSIT IS DUE WITHIN 24 HOURS OF AUCTION END.
John Deere Gator XUV560S4 4x4 Utility Cart (A50324)
John Deere Gator...
2019 Kenworth T270 Truck, VIN # 2NKHHM6X3KM358768 (A51572)
2019 Kenworth T270...
2025 New/Unused LandHero 1 in Air Impact Wrench (A51573)
2025 New/Unused...
2025 New/Unused LandHonor 13,000lb Electric Winch (A51573)
2025 New/Unused...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
