What equipment would you need to change this tire
   / What equipment would you need to change this tire #1
millpond
NH TC 55 DA
Just dreaming that some day after all the clearing is done I would change my AG R1 tires over to turfs for summer field work. BUT can one person change 14.9-24 rears on NH TC 55 DA which have been loaded. What equipment would I need, other that jack/jacks to safely move tires around. I think I read in one thread the tires loaded are 500+ pounds.(damageous) So what
would one need for this change over..:confused:
   / What equipment would you need to change this tire #2
Do they fit the same rims?
Depends how fancy you want to get / which equates to how much you want to spend.
Couple long "spud" bars is what most the tire guys I know handle these with, that said, they make all sorts of jacks, cradles etc.
Trick is to make leverage work for you, and not let the tire get heading a direction you wish it not too go.
If it is the same rim, just leave the rim on the tractor, and change over the tires.
I think it was Gemplers that had a pretty good slide show about how to change tires.
   / What equipment would you need to change this tire #3
If you are saying you want to put turf tires on ag rims it will not work. They require a different size rim.
Now if you are talking about removing the tire and rim combo to replace with a different tire rim combo that is fine. With filled tires they will be heavy and it is best to have some help. What I do is just keep them balanced and roll them someplace to lean them up. If one were to start to fall I would not try to catch it.
MarkV
   / What equipment would you need to change this tire #4
Yea, like those guys said. If you plan to take the loaded tire & rim off the tractor, be sure to either jack just one tire at a time off the ground or use 2 jacks, one on each side and as far outboard as they'll go. If you jack in the middle and take one side off the tractor will fall over. When I bought my old IH 340 didn't know the tires were loaded and found out the hard way. Those tires are in that general weight range, 300 - 600 lbs. depending how full.
   / What equipment would you need to change this tire #5
**** we roll around 20/38's with solid centres that probably weigh more than this empty ,you only need common sense .Dont let em lay down ,keep it upright?
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A52128)
2017 Yale GLC050VX...
Wolverine Quick Attach Skid Steer Rock Rake (A50514)
Wolverine Quick...
2018 CAT 320GC Excavator (A47384)
2018 CAT 320GC...
UNUSED FUTURE SKID STEER HYD MIXING BUCKET (A51244)
UNUSED FUTURE SKID...
2013 John Deere 310SK (A47384)
2013 John Deere...
2021 John Deere 333G Two-Speed Hi Flow Compact Track Loader Skid Steer (A50322)
2021 John Deere...
