What else do I want? (Wish List)
   / What else do I want? (Wish List)
Harrow/Drag is a possibility, but that might be something I make with chainlink fence and timbers.
A rake would be interesting, but my rock is 3" or less, so the tines would have to be close enough to grab those.
   / What else do I want? (Wish List) #12
I'm not interested in 'SS' anything.
The uses I've seen for boom poles raising trusses attach to the FEL to greatly extend the reach upwards, enough to get over an 8-10 wall.
MT125 isn't SSQA bucket? ewww....I thought they were same as XJ.
I must be confused on what a boom pole is then....I thought those were the L-shaped pole that went on your 3pt with a pulley or hook at the end. Kind of like a cherry picker engine hoist.
   / What else do I want? (Wish List) #14
Humans tend to be obsessive! I know a guy who can't stop buying a particular (high Quality) brand of tools. That Andrew Camarata (on Youtube) can't seem to stop buying equipment either. Buys a Yanmar Mini-ex, same as he has, then blows a hose, is fixing it, but you suddenly see him driving up (again) and has yet another bigger hoe, that he just had to buy from a guy down the road. I know another guy just like that.
Sometimes less is more and the law of deminishing returns ALWAYS applies! Just how many batteries, tires, pumps, hoses and rads does a guy really want to own?
No SS at either end. Pin-on only.
Pole may be the same concept but modified for front use instead of rear. There are a few threads about shop/shed builds that mention them.
   / What else do I want? (Wish List) #16
As you have found out, most used attachments are for larger tractors usually Cat 1, 2, or 3. Your MT125 probably requires Cat 0 attachments. Used Cat 0 attachments are pretty scarce unless you buy new. If not in a hurry, they do occassionally come up for sale. I've seen them on CL from time to time. Without a truck or trailer to pick up attachments you are at the mercy of the seller to deliver unless you can borrow a truck. For QA forks look for the lightest pair for your tractor due to you lift capacity. Everything Attachments has pin on to QA adpters so you may want to contact them. Best of luck and keep looking.
   / What else do I want? (Wish List) #17
I thought I wanted a PHD, but I'm not sure I have the ongoing need.
I can see uses for pallet forks, but not sure if I want a dedicated set or FEL addons.
I probably need some sort of back blade, but not necessarily a box blade.
Thing is, most of the listings I find are for larger machines. Neighbor's got some stuff, but the pins and what not are all too wide.
With no truck, I don't need a trailer.
Boom pole? Hmmmm.... I've seen some posts about people using them to lift trusses into place and I'll probably need to rebuild my shed in the next couple of years.
add truck and trailer to your wish list, how could you operate your farm without those??..
   / What else do I want? (Wish List) #18
I made a drag with chain link and a fence post..nothing I could do would make it drag straight. And I tried everything. evfen different surfaces. flipping it over, etc. frustrating. shelved it for now.
The rake can possibly do the same thing - i'm thinking of it for dirt smoothing, horse riding arena grooming (harrow, fence drag..) and use in the pasture in the spring to break up the horse manure that accumulates over the winter.
2022 Club Car Tempo Cart (A55852)
2022 Club Car...
White 6175 Work Horse Tractor (A59814)
White 6175 Work...
Butler MFG Water Tanker (A56438)
Butler MFG Water...
Toro Greenspro 1260 Towable Greens Roller (A56859)
Toro Greenspro...
2009 Kubota RTV1140 (A57148)
2009 Kubota...
Krause 4223 Field Cultivator (A59814)
Krause 4223 Field...
