what does"turned up" mean?
/ what does"turned up" mean? #1
kingcutter
i have an 2007asv rc100 with a loftness carbide cutter and read a post about a hydraulic leak and they said it happened before they "turned it up"
are they adjusting it for more hyd. pressure?
/ what does"turned up" mean? #2
That's not much information for us to go on. I Googled TBN for "turned it up" and found seven threads, but none of them related to hydraulic leaks.
Could you possibly provide a link to the post where you saw that, or cut/paste the post you read?
/ what does"turned up" mean? #3
Hi kingcutter, welcome to TBN
You're asking about this thread? http://www.tractorbynet.com/forums/construction-equipment/121052-asv-leak.html
Sure sounds like that's what "turned up" means. First you should repair your leak, then you can think about adjusting the relief for higher pressure. It'll just leak quicker if you do anything to raise the pressure.
Let us know what you find and how you fixed it.
good luck.........
/ what does"turned up" mean? #4
There is a screw on the pump that increases the pressure. I think stock is 3300 psi, my machine is at 4300 psi...I know DirtyWorks had his to 5000 psi.
thanks for the info. thats what i thought they were talking about and i wanted to see how they did it. i currently have a small leak from one of the motor hose connections and im trying to narrow it down.
I STILL LOVE THIS RC100!
/ what does"turned up" mean? #6
Give it some time, you'll learn to hate it.
/ what does"turned up" mean? #8
kingcutter said:
what problems have you had?
One thing Kingcutter, higher pressure means lower flow. The cutter will respond faster but will probably stall faster too unless the flow is increased along with the pressure. Just my 0.02 I may be completely wrong.
/ what does"turned up" mean? #9
Very good post by Westshore. Pressure and Flow work opposite of each other - think of a garden hose. To increase pressure, you put your thumb over the end of it - more pressure but less flow.
Magnolia Trailer with Adams 25 Ton Fertilizer Tender (A63688)
Magnolia Trailer...
5K Yale Forklift (A63688)
5K Yale Forklift...
2023 Ford F-350 4x4 Flatbed Truck, VIN # 1FTRF3DM5PEC15665 (A65563)
2023 Ford F-350...
2021 SANY SY265C LC LONG REACH EXCAVATOR (A63276)
2021 SANY SY265C...
1984 Charles Machine Works S4A S/A Tilt Deck Trailer (A61573)
1984 Charles...
2003 Kenworth W900 L Model (A62613)
2003 Kenworth W900...
