What does this mean?
   / What does this mean? #1
aspg4
texarkana, ar
Massey Fergerson 135, TYM 554
Anyone know what these symbols mean on my dash monitor. SPN:0 and under it FM1:0 The symbols flash on and off..
   / What does this mean? #2
Your display is showing you have a active fault code. SPN stands for Suspect Parameter Number and FMI stands for Failure Mode Identifer. Usually after the SPN you will have a three or four digit number and after the FMI it will be a one or two digit number. Once you have the numbers you could call your dealer and he can tell you what the fault is. Hope this helped.
Thank you very much. The display on both show 0. The original display went bad, and it was replaced by a new one. It has been showing these symbols ever since the new display was installed. Maybe something was not plugged in correctly..
   / What does this mean? #4
Either what you say aspg4 or a portion of the software has not be calibrated with the new display. Call the dealer.
2025 K0520 UNUSED Welded Wire Mesh Roll (A50860)
2025 K0520 UNUSED...
2021 Chevrolet Tahoe FL SUV (A48082)
2021 Chevrolet...
SCAN FOR HAULING AND FINANCING INFORMATION (A51242)
SCAN FOR HAULING...
2014 CATERPILLAR 277D SKID STEER LOADER (A51222)
2014 CATERPILLAR...
2012 Ford F-350 Omaha Crane Service Truck (A48081)
2012 Ford F-350...
2015 MACK GU713 (A50854)
2015 MACK GU713...
