What does my TC40 need for a 3pt log splitter
   / What does my TC40 need for a 3pt log splitter #1
RobertN
Super Member
Shingle Springs California
New Holland TC40D
There is a used 3pt log splitter available locally.
My TC40D is bone stock; no add on's. If I buy this log splitter, what do I need to get hydraulics to it from the tractor? I do not have top/tilt or anything yet...
   / What does my TC40 need for a 3pt log splitter #2
Power beyond hydraulic circuit.
   / What does my TC40 need for a 3pt log splitter #3
Or a set of remotes. At least I run my splitter off the remotes with no problems and the remotes are handy for other attachments too.
   / What does my TC40 need for a 3pt log splitter #4
Robert, if you want, you can run your splitter off the loader quick connects. You'll just need to buy fittings and longer hoses. You can't use your loader when you are running the splitter anyhow. If you want, you can mount that splitter on a small trailer and put it anywhere around your tractor. It doesn't have to be on the 3PH. You can set it to the right side of your tractor and have easy hookup to the FEL quick connects and access to the joystick to start hydraulic flow.
If you decide to go with remotes, it will be a little over $500 for your first remote valve/fittings. That's probably more than the splitter will cost.
It(splitter) was gone already...
I want to add TnT, but can't do it right now. I made my own setup on my previous Kubota; I used the TnT all the time. When I add the TnT, I'll make sure I have a remote port too.
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A51222)
2006 CHEVROLET...
2005 Ford F-550 Bucket Truck, VIN # 1FDAF56P45EB88239 (A48836)
2005 Ford F-550...
2015 MACK GU713 (A50854)
2015 MACK GU713...
72In FEL HD Round Back Bucket (A51039)
72In FEL HD Round...
2021 Liebherr L556 (A51039)
2021 Liebherr L556...
2006 Peterbilt 379 T/A Sleep Cab Truck Tractor (A49461)
2006 Peterbilt 379...
