What do YOU use to cut metal roof panels?
   / What do YOU use to cut metal roof panels? #1
Diggin It
Super Star Member
I'm thinking, I'm thinking!
LS MT125 TLBM
Starting a roof project, 29G 5 Rib panels and trim ordered. In the past, I've used an abrasive cutoff blade in a regular circular saw. Tin snips/shears are OK for small pieces and trim, but they don't work well for me for long cuts. Considering an air or electric nibbler or shear. I seem to recall some posts here about people using regular circular saw blades, but I'm not sure how well they would work.
So, what have YOU used?
   / What do YOU use to cut metal roof panels? #2
I have used plywood cutting blades turned backwards no carbide tips good luck with your project.
604942d1558001229-what-do-you-use-cut-blank-jpg
That doesn't tell me much.
   / What do YOU use to cut metal roof panels? #5
I have used a circular saw with standard blade backwards, the metal saw with the 2 counter-rotating blades, an air shear and an air nibbler. I always try and get panels cut to the exact length so there is not an extreme amount of cutting. I do not like the hot chips from the saws. I use a nibbler whenever I can.
The last of 3 buildings Morton built for me the only tool they used was a nibbler. Their panels are quite a bit thicker. The only thing most people use 29 gauge for around here is putting over old wood siding on barns or interior ceilings in shops.
My problem with nibblers and shears is the profile of the ribs. Even cutting from the back is sometimes difficult. An abrasive blade handles that a lot better and produces only dust, no chips.
I try to get panels cut to size where possible, but I have several to cut at angles for valleys, so precut isn't possible.
29G is standard for residential roofing jobs.
   / What do YOU use to cut metal roof panels? #7
This saw is amazing at cutting metal roofing along with a lot of other materials, it's expensive but works great. Along with roofing, I've cut 1/2" thick steel and 1" thick aluminum with it. There are knock off brands out there as well. I've learned that cutting roofing with it, it's best to do it on the bottom or flat side which makes all the angle cuts backwards and sometimes ruins a piece, don't ask how I know.
8" Metal Cutting Saw
   / What do YOU use to cut metal roof panels? #8
I have one four bay carport and one single bay carport. All have galvy metal roofs. I purchased the roofing in lengths so I could overlap and not have to do any cutting. Overlap on both length and width.
   / What do YOU use to cut metal roof panels? #9
I used to cut roofing metal with a circular saw. Just put in any old blade backwards and cut. I got tired of the noise and hot chips so switched to a pair of tin snips. It's quick and works very well.
I don't do expensive because I don't do this stuff often. A 7" Dewalt abrasive blade will run me under $5, so I'll have a couple on hand.
Because of the varying lengths as I work along the valleys, I plan on using roof felt paper to make a template for each panel, then lay those backwards on the back side of the panel. Cutting from the back will handle the rib profiles better. Don't ask me about backwards angle cuts either. Been there.
I was hoping that somebody could convince me an air nibbler or air shear would handle the ribs better, but it's not looking that way. They'd be fine for flat stock and trim, but I can use regular tin snips for those.
JOHN DEERE 3032E TRACTOR (A51247)
JOHN DEERE 3032E...
2025 New/Unused Wolverine 48in Skid Steer Trencher (A51573)
2025 New/Unused...
2024 JOHN DEERE 3039R LOT NUMBER 165 (A53084)
2024 JOHN DEERE...
2018 FORD EXPEDITION (A51406)
2018 FORD...
Miller Wildcat 350-D Welder (A51691)
Miller Wildcat...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A52576)
2018 FREIGHTLINER...
