What do you use the regen function for?
   / What do you use the regen function for? #11
That "sounds" like the curl function lines are swapped. On a most tractors the regen only functions on the dump side. If connected to the curl side it effectively reduces the working area of the hydraulic cylinders to the shaft side as it will pull pressure to both side of the cylinder.
This would cause the dump motion you speak of if the bucket was full as the relief valve is overwhelmed then the circuit is moved to normal no regen.
I have no experience with JD though as most brands the regen position is past the normal dump position. /forums/images/graemlins/confused.gif
</font><font color="blue" class="small">( I have recently taken possession of a new 4310 w/430 loader. I was using it this past weekend (without reading the manual) and when I would try to roll the bucket back, it seemed to dump first, then roll back. /forums/images/graemlins/confused.gif I thought there was something wrong with it. Then I sit down that night and read the manual and discover the "regen" position, which is obviously what I was hitting. /forums/images/graemlins/crazy.gif I just wonder what most of you use this for, and/or do you lock it out?
)</font>
   / What do you use the regen function for? #12
Kenny,
Once more, Thanks. I must have been pretty tired last night when I posted that. I woke up this a.m. and thought "That Lock-out has nothing to do with regen...it's a simple slide lock to prevent the SCV from moving at all". Amazing what some sleep will do for the thought process.
Also, thanks for the links to the full explanation and pic of the regen. They're excellent. Would be nice if the manual made, at least, a cursory reference to regen.
Tom
2012 AMERITRAIL (A55745)
2012 AMERITRAIL...
Adams 16T Tender Body (A56436)
Adams 16T Tender...
EVINRUDE OUTBOARD MOTOR (A58374)
EVINRUDE OUTBOARD...
SAKAI SV414D SMOOTH DRUM ROLLER (A52709)
SAKAI SV414D...
New/Unused CFG Industrial MH12RX Mini Excavator (A57453)
New/Unused CFG...
2017 Bobcat T450 Compact Track Loader Skid Steer (A56857)
2017 Bobcat T450...
