What do you look at when inspecting a house?
   / What do you look at when inspecting a house? #21
I would also be there while he does the inspection.
The inspector is miss a few things. Over all it was worth the money imho.
   / What do you look at when inspecting a house? #22
I remodel and repair homes for a living. I've also bought and flipped a dozen houses and built and sold another dozen spec homes. When looking to buy a house, the most important thing for me is to know what the comps are in the area. Is the asking price a deal or will it be a money pit? How long has it been on the market? Are they still living there or have they already moved out?
Then it starts with the neighborhood. Do I like the drive to get there? What do the houses look like in the neighborhood? Are they kept up? Trashy?
I carry a notepad and a flashlight. I do this for homes I'm looking at for myself, but also with clients looking at their houses.
Curb appeal is huge. It doesn't have to have it for me to buy it, but it has to have the potential to have it. Some houses are just too ugly to mess with, others just need a few changes to look nice.
Before walking into a house, I'm looking at the roof to make sure it's flat. Does it have valleys full of leaves? Flashing where it's supposed to? Condition of the shingles and rot on the fascia. Trees over the roof? Then I look around the windows and foundation for cracks in the brick. If its covered in vinyl, I'm suspicious of what they are hiding. Is it freshly painted and if so, what are they hiding?
Once inside, I take a deep breath and hope it smells good. Lots of homes stink. Pets, smoking and dust are pretty common. Mold, mildew and funk are huge warning signs that I come across that home owners somehow don't seem to notice.
Walk every room, make sure the floors are flat and level, look for cracks in the walls, or repair jobs to hide the cracks. Look at the bottoms of the window sills for staining and leaks. Do the doors open and close properly and are they aligned with the trim?
Look under the sinks for leaks and armature plumbing repairs. Look all around the toilet for leaks. Funny how many toilets are not even bolted down and there is "stuff" behind them.
What does the electrical panel look like? Any modifications?
Poke your head into the attic and shine a flashlight all around. Look cracks in any of the lumber up there. Look for support beams that have been cut to get plumbing or AC ducts to fit. Look for staining on the decking. Make sure there is decking and note it's condition. I hate plywood decking because it tears apart so quickly from being nailed, but in older homes its usually a variety of 1x wood that has gaps. Sometimes those gaps are huge!!! Smell for animal droppings, look for vents and make sure the soffit vents are open. Is the HVAC unit up there? Has it been maintained? Is there water in the pan? How much insulation is up there? The new standard is 24 inches, but most attics will be lucky to have enough to cover the 2x6 joists.
If all is well, then I start to run the numbers on what it will take to remodel and update the house. Does it need remodeling or is it just like how you want it? Can you live with it for awhile? Some things like new flooring and paint can be negotiated into the contract when buying it. Find everything you can wrong with the house and write it all down with a value on what it will cost to fix or change it. A lot of the time they will take that amount of the asking price.
Most importantly, do not fall in love with it and go into it not expecting to buy it. I look for reasons not to buy a property. There will always be another out there, and in every case that I've come across a person who hates their house, it's because they bought too quickly. The longer you take to find the right house, the more you can save up for your down payment, or to have available for improvements.
If you find the house you want, take the advice that just about everyone has given and hire a professional home inspector. While most are pretty good, be careful of the one the realtor recommends or uses all the time. Every now and then one of them turns out to be a rubber stamp and does what it takes to get the house sold so they can continue to get jobs from that realtor instead of looking out for you.
NEVER TRUST YOUR REALTOR!!!! While most are great people, it's very rare for one to admit that they don't know something or they can tell you what's' wrong with the house. Worse is when they give advice on what it's worth or what it will take to fix it up. Repeatedly I've been told by clients that their realtor said the problem with the house was a simple fix, or something easy for a pro to take care of that wont cost very much. If you find something wrong that needs to be fixed, get several bids on it and know exactly what it will take to fix it from somebody who does that for a living.!!!
Good luck,
Eddie
   / What do you look at when inspecting a house? #23
A great write up Eddie - thanks. You have the advantage of being in the right job where as most people don't have your knowledge and experience.
In Canada - BC specifically (until very recently), home inspectors were/are not trained per se. They do a two or three week course and armed with that education, are allowed to go out a reek havoc on unsuspecting home buyers. There far too many reports of major problems going undetected and worse still, deliberate misleading statements on house condition.
Who determines a good home inspector - they are all called good until one finds out otherwise and it really costs you. I particularly like the advice regarding Realtors - I am sure a lot of people unsuspectingly,put their faith in the Realtor.
Thanks again Eddie, for the excellent presentation.
   / What do you look at when inspecting a house? #24
Realtors around here know nothing about home construction and publically admit it...
It's all part of the mandatory disclosure that paper a deal to death... the contracts all refer to seeking advice from construction professionals, city and county records, engineers, etc...
It's just like California Prop 65 warning regarding cancer... I doubt you can find a building anywhere without a Warning state Chemicals Known to the State of California to cause Cancer MAY be here...
Eddie hit the nail on the head...
   / What do you look at when inspecting a house? #25
One is correct to view home inspectors with skepticism. A decade or so ago I did some work for a homeowner. One of the jobs was to dig out about 15 feet of conventional clapboard wall that was about a foot BELOW GRADE. This poor guy knew nothing about construction and had relied on a recent home inspection.
   / What do you look at when inspecting a house? #26
The first thing I'd check is the foundation and then check for mold, wood rot etc.
If the foundation isn't good and there's too much rot then I wouldn't want it. I wouldn't care if it needed plumbing or electrical work as I love to do that work.
I also love to do carpentry. But if the rot has gotten really bad then it's most likely not worth the hassle of repairing nor the cost.
Chad
   / What do you look at when inspecting a house? #27
That is so true!!! When we were looking for a house, my buddy told me someone has to be the Downer. Put down the house, look for what is wrong, don't fall in love with what you see because a lot will be cosmetic. We looked for 7 mts until we found our house, it was the one house I walked out saying how do I talk my wife into this, and she though the same thing.
   / What do you look at when inspecting a house? #28
Besides great tips given above at least from area where I currently reside I would also look out for Chinese drywall. :eek:
   / What do you look at when inspecting a house? #29
Not many have mentioned the need for a clear title. How many threads have been started because of problems resulting from this?
   / What do you look at when inspecting a house? #30
Never had a title issue become a problem... the Pre that is run at the time of listing would kill the listing if the Title is clouded.
Year: 2014 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 (A55852)
Year: 2014 Make...
1982 LeeBoy Motor Grader (A55302)
1982 LeeBoy Motor...
2018 Cadillac Armbruster 70IN Limo - 43,279 Miles, Professional Coachwork, Clean Executive Vehicle (A55315)
2018 Cadillac...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A55315)
2023 Unverferth...
2014 MACK PINNACLE (A55745)
2014 MACK PINNACLE...
INTERNATIONAL DUMP TRUCK (A52707)
INTERNATIONAL DUMP...
