What do you have for a first aid/trauma kit?
   / What do you have for a first aid/trauma kit? #31
While looking at camps today, found these guys. We had our sawyer 1st aid kit along that includes epi pens. Years ago I asked my doc I wanted some and he said "sure" and wrote me a scrip.
   / What do you have for a first aid/trauma kit? #32
I have a small mymedic kit on my work backpack, the superskin bandages are really good. I should probably get another one for the garage/tractor
   / What do you have for a first aid/trauma kit? #33
We typically go camping with two other couples as a constant amid others. Those two are almost always there. One is a semi-retired EMT that currently works teaching new hires the classes they need. He has been our First Aid Kit a couple of times. (broken arm, then a broken wrist). We don't leave home without him! (we do have a kit in the bathroom designed by him)
David from jax
   / What do you have for a first aid/trauma kit? #34
David from jax
Whats in the kit?
   / What do you have for a first aid/trauma kit? #35
Pertaining to stopping bleeding; now a product is made that has a battery-pump to pressurize an air pressure tourniquet for arms and legs. That would be invaluable for a chain saw injury, as a chain saw doesn't cut, it tears away the flesh.
Obviously not for a neck wound_.
You could use a manual blood pressure cuff and just maintain it above the systolic pressure. Ya, on the neck wound. :)
   / What do you have for a first aid/trauma kit? #36
I've always made it a point to be prepared. This also includes fire extinguishers and first aid/trauma kits. In my truck, I carry a self made first aid/trauma kit. Most first aid kits are loaded with bandaids, lotions and aspirin. I wanted a kit that was better suited for job site or outdoor injuries. Like injuries from livestock, chainsaws, job site tools, gunshot or knife injuries. So, I put together a hybrid kit that has bleeding care supplies (clotting gauze etc.), tourniquet, sucking chest wound, splint, eyewash as well as a reasonable set of band aids.
I also made every member provide an emergency contact number.
What does everyone else do for first aid/trauma kits?
Excellent post and too often overlooked by all of us because "it'll never happen to me".
We can't prepare for every eventuality but at least having something for the main type of hazard you are facing in a particular area is a start. I worked as an EMT for many years and having an emergency contact number is a critical bit of information to carry with you. I have been as much of a slacker as anyone in this area. Too many years of working on remote or hazardous assignments and being out of touch with family and friends.
As said, excellent post and a good reminder for all of us, including me.
Thank you.
   / What do you have for a first aid/trauma kit? #37
Small, "all in one" type first aid kits. Often left over ones from work, that "technically expired" because of the eye wash saline...
In my experience, a first aid kit, no matter how large or well equipped, is only good for a single moderate incident. No, ouchy/boo-boo, but even a smaller, first aid required cut, you (or your patient) is gonna bleed all over everything, half of it will end up in the dirt digging through it. Guess the point is, $30 kit, single real use; $300 kit, also single real use; only difference is how much is wasted.
   / What do you have for a first aid/trauma kit? #38
I put one of these kits in each of our fire trucks. They sit in the cab under the driver's seat. Even though your rescue truck or engine may be very well equipped, it also may be a quarter mile away if something happens at a brush fire (chainsaw injury, impalement, etc) or a crash scene. These kits provide some cheap peace of mind.
The contents is packed into ziploc bags to keep them from getting dusty. Then that is packed inside a cheap tool bag from Harbor Freight, but you could use any bag you like. I bought the same bag so they were consistent across all the trucks.
Trauma Kit Contents:
Pocket CPR mask
Oral airway
Trauma shears
5x9 trauma dressing (2-3)
Gauze roll 3" (3)
Elastic bandage (1)
Triangular bandage (1)
Petroleum jelly dressing (1)
Tourniquet
Gloves (4)
Hand wipes
Sharpie marker
A neighboring FD has gone to carrying a scaled-down version of this kit in their EMS jumpsuits. If something goes south, there's no running back to the truck.
   / What do you have for a first aid/trauma kit? #39
Yes to the superglue. Great to stop nuisance bleeds. Quick clot and tourniquet for GSW and other serious stuff.
   / What do you have for a first aid/trauma kit? #40
So, I'm assuming personal and/or family use, or your specific crew if work...
I'll share what our first aid teacher (a paramedic and trained first aid teacher), at work said; "this is for yourself and immediate family, or as required by work; I would Not recommend stopping and offer aid outside of those situations, to the general public"
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A55302)
Kubota SVL65-2...
2019 CATERPILLAR D6T LGP HI-TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
UNUSED Tool Set (A53117)
UNUSED Tool Set...
6" CONVEYOR BELT (A54757)
6" CONVEYOR BELT...
2023 Bobcat E60 (A53317)
2023 Bobcat E60...
2013 Ford Fusion SE Sedan (A55853)
2013 Ford Fusion...
