What do you guy's think? CK30
   / What do you guy's think? CK30 #1
gippolit
New Jersey
CK30HST Loader Backhoe
What do you guy\'s think? CK30
I've changed my mind. I think I'm going to get the CK30hst with a Rhino back hoe 85 and the 130 loader. Also the dealer is going to install rear work lights, conopy and pads for the hoe. All for 21,500.
Does this sound ok
Thanks
   / What do you guy's think? CK30 #2
Re: What do you guy\'s think? CK30
I am not sure I would put the 85 backhoe on the machine.
Why not? I would really like to know. Thanks
Glen
   / What do you guy's think? CK30 #4
DK35vince has the Rhino 85 BH and may be able to give you some sound advice. You may want to try and PM him. Gerard
   / What do you guy's think? CK30 #5
Kioti only approves up to a 7.5' hoe for that model. Going to the one foot larger 85 will void the warranty if there is a problem. The R&D department tested models with different backhoe sizes, and that is what they set for max size.
I personally think that frame could handle the subframe mounted 8.5', but my opinion doesn't count. You would need to get a waiver in writing from Kioti/Daedong to insure they would warranty any problems the larger BH caused.
I'd simply go for the 75 on that model.
As for the price, it's not bad for the named items. John
   / What do you guy's think? CK30 #6
Guess you beat Vince with an answer. /forums/images/graemlins/wink.gif Gerard
I've asked my dealer about this and he said I don't need worry. Should I contact Kioti and make sure? Thanks for all your help!
</font><font color="blue" class="small">( Kioti only approves up to a 7.5' hoe for that model. Going to the one foot larger 85 will void the warranty if there is a problem. The R&D department tested models with different backhoe sizes, and that is what they set for max size.
As for the price, it's not bad for the named items. John )</font>
   / What do you guy's think? CK30 #8
A BH can be pretty rough on a tractor and can break it in half or tear off parts of the rear end.
If Kioti recommends the 75 as the largest for the CK30, that is as large as I would go. If you want/need a bigger BH, I think you should seriously consider stepping up to the DK35/40 if Kioti suggests they are a good fit for the 85.
I would want a letter from Kioti (not the local dealership) saying that they will honor the warrenty on the CK30 if you install the 85, otherwise I would go up in tractor size to get the larger BH.
   / What do you guy's think? CK30 #9
<font color="blue"> Should I contact Kioti and make sure?</font>
Most definitely. Gerard
I called Kioti, but someone has to call me back. Thanks for all your help
</font><font color="blue" class="small">( <font color="blue"> Should I contact Kioti and make sure?</font>
Most definitely. Gerard )</font>
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
2005 Ford F-250 4x4 Reading Crane Service Truck (A51692)
2005 Ford F-250...
1992 Peterbilt 377 Sleeper Cab (A53472)
1992 Peterbilt 377...
2012 International 4300 Reefer Truck (A53472)
2012 International...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
2006 Ford Focus Sedan (A51694)
2006 Ford Focus...
