I use about the same weight rotary cutter on my BX2230,It's a Land Pride RC1548.It weigh's about 460lb,Ihave no problems plenty of power,I used lower pin hole location's for lift arm pins,Tractor lift's it plenty high.I'm not filmilar with woods if they have different locations for pins,if not this could be a problem as our subcompact's have lower tires which limit 3pt lifting height.Also leave loader on for counter balance or add weight's to front as some dips or hills could cause you to kiss the raditor "not fun".One other thing you'll need to address is pto shaft lenght you will most likely need to shorten it,I had to cut 5 1/2" off each pc to fit,not a problem.I hope this help's,I do think you are better off buying a good used heavy duty model in good shape.If you shop around a little you can find them in the $350-$500 range and some are like new! and will last a long time.
