What do I need
/ What do I need #1
kernal
Rochester NY
JD 2320
Working on cleaning up what the previous owner used as a kettle hole. IE, dumping pit for everything they didn't want. The little 2320 made quick work of piling it up, but now what do do with it. I either need to move it to a different part of my property, or load it up to get rid of. Instead of dumping everything out back, this is in front yard. I am wondering what is available for the 200cx, and will save my back. Pictures show the current project, but in the future there will be brush cleanup, landscape projects, who knows what. I am looking for options, pallet forks, brush fork, grapple. Ideally I'd like something to pull the junk out and leave the soil.
Scott
/ What do I need #2
I had similar work recently, cleaning up two old brush piles. When I got down to the bottom of the brush piles, I had quite a few partially-buried trees that needed to come out, so I used my pallet forks to spear down into the soil and pop them up.
This worked pretty well for me. If I needed to pick up lots of brush piles and strain the dirt out, I'd probably look for one of those comb-like thingies that attaches to the loader bucket.
I've seen pictures of 2520's with grapples on them, but not sure how a machine in that size range would handle with a grapple.
Good luck.
/ What do I need
On a side note, does anyone know if the 3rd scv for the 2320/2520 was released?
/ What do I need #4
Yeah, that right there is the biggest problem. A set of debris or brush forks will work to pick up the stuff, but may not get all the dirt out of it. What you need is something that can "grab and shake" to let the dirt fall out. What about getting a thumb for your backhoe? That way, you can at least make a cleaner pile first, then move it using some forks.
/ What do I need
Thumb, and Forks are already on the list of needed tools. I have been looking at the grapple threads and the Millonzi 48" grapple looks like the ticket. Only about 80 lbs more than the bucket I have. Who makes a thumb for the 46 bh, have not had any luck finding any threads on that. Mostly see the bro-tek for the kubota's.
I did find an ATI bolt on grapple on the local craigslist. If I had the time that could be modified to a brush grapple. That could be a fun project.
/ What do I need #7
I have not seen thumbs for the 46BH either...A few people with that model should call Bro-Tek and let them know there is interest in one.
/ What do I need #8
I saw a very nice looking Bradco rock bucket the other day. It was only about 4' wide and looked like just the ticket for our smaller tractors. The one I saw was a skid steer mount :( and I don't see it at their web site yet, but it might be worth a look. Here is a link to their larger ones.
Bradco
/ What do I need
Well, I picked up an ATI bolt on grapple, now I need to get a diverter setup. Looked over Kennyd's thread on adding a diverter on his 4110. I figured the price was right, and I am looking into building or buying a brush fork so I can move this to either.
Plus after cutting a few tress down saturday am I decided I needed something to assist in the brush cleanup. A quick trip to the local dealer and a set of Frontier pallet forks made cleanup really quick.
any thought's about bolting the grapple to the forks?
Scott
/ What do I need #10
Very nice Scott!
I'd love to see pictures of your remote install also!
/ What do I need #14
arrabil said:
I'm interested... I'd like to get TNT and operate both cylinders with the 3rd SCV lever. Ideally I'd like a 3-way valve for a currently un-thought-of use.
Anything wrong with this one?
Surplus Center Triple Selector Valve
That will work just fine, but the wiring may be a little tricky. Someone here on TBN used this valve and got it figured out...I will try to remember his name-it was posted in the hydraulic forum.
/ What do I need #15
Found it HERE, maybe you can PM him or reply to the post and see if he got it wired?
/ What do I need #16
Without having read the link... my thinking was a "master" switch with a relay that allowed operation of the other two switches. That way either the preferred path is on and the other two bypassed, or the preferred path is off and the other two switches choose the route.
Now lets see if thats what the other person did. :)
/ What do I need #17
kennyd said:
I think you need a set of forks, and a grapple. Search for "Millonzi" for LOTS of great grapple threads.
Just remember that they, in particular, are probably OUT-OF-BUSINESS...:(
Even though their website is still up...:confused:
/ What do I need #18
Yes, I posted that before it was discovered that they have gone south...
/ What do I need
Yeah, That's why I picked up the ATI bolt on grapple when I saw it.
Kenny, you mentioned another valve, I'm all ear's.
/ What do I need #20
WR Long has a "kit" they will sell you for about $550.00 or so...
And THIS ONE from the SurplusCenter will also work...but it's bigger.
