What do i need to sharpen bsh hog blade?
   / What do i need to sharpen bsh hog blade? #1
CMV
Platinum Member
NC
Kioti NX4510HST (previous LS XJ2025H, JD 500C)
Bush Hog BH 6. My impact driver is a smaller 3/8 one about the size of a cordless drill so I'm sure that isn't up to the task. Does anyone know what size/spec impact driver, socket size, or anything else I'll want to have on hand to do this? It's a remote site so don't want to make extra trip since i didn't think to bring X with me.
If i remember right from when it was new, 'sharpen' isn't right term. It was much more blunt that a typical mover blade new. So I just take an angle grinder to it & get the dings out - I'm not looking for any type of knife edge correct?
   / What do i need to sharpen bsh hog blade? #2
It is better if you CANNOT shave with it. Your 1/4" impact isn't up to the job, but a 1/2" impact will do the deed. Almost guaranteed.
   / What do i need to sharpen bsh hog blade? #3
You don’t need an impact driver. I always use a half inch breaker bar and about 3 foot pipe extension.
   / What do i need to sharpen bsh hog blade? #4
The nicks aren't so bad. Don't try to remove them, too much stock to remove. On mower blades we sharpen to a 1/32" flat (.030"). On a BH blade 1/16" (.060") is darn sharp.
btw, if anyone ever considers hard-facing a blade's cutting edge be sure it's done neatly or you may give up on sharpening it long before you grind an 'edge' on the bead.
btw, Chris, did you get that Howa to shoot OK? Getting the seating depth right first beats trying 'X' powders before knowing what the throat prefers for each pill.
(You new that. Others might not have heard yet. :))
I got it to about an inch & a half, but not the cloverleaf I'm still chasing :) Your stuff helped a LOT!
   / What do i need to sharpen bsh hog blade? #7
I use the blue wrench on a lot of chassis and powertrain stuff. The typical three ears holding a car's front wheel bearing cartridge to the knuckle are a common use to remove the bolts w/o snapping them off. I don't have to keep them hot to remove, they come out easily once they've been red. Monte Carlo (2R, 1L) and Jeep Wrangler (L) were my latest. ('17-'19)
Blades may mount by std or by shoulder bolts. Don't ever replace with SS hoping to dodge rust, they won't last. If you can get a jam nut on threads protruding through the flange, grease threads, tighten well, and remember they're there if you'll r&r the blades again someday.
(See below :))
   / What do i need to sharpen bsh hog blade? #8
Guess I'm confused whether you're talking about removing the blades and/or sharpening them.
I remove mine with a 3/4" socket driver with a 6 ft piece of pipe that slides over it. Retorque it the same way: more or less give it all I have to tighten.
You do not "sharpen" the blades. You take the big lumps caused by gouges in the blade and smooth them out quite a bit on one side and a little bit on the other side. I grind mine on a bench grinder, keeping track of the # of times I pass the entire length of the cut edge so as to try to keep it near the same weight as the other other. It won't be anywhere near sharp, but it'll cut grass. I don't see how you could keep them in place to use a hand-held grinder on a drill.
Ralph
   / What do i need to sharpen bsh hog blade? #9
Why take them off at all? reach under with an angle grinder and sharpen them in place. I do it all the time on 4 different rotary cutters. Raise it as high as it will go and put some blocks under it to be safe.
   / What do i need to sharpen bsh hog blade? #10
I gently flip the bushhog over, using the FEL, and then run an angle grinder on the blades.
NEW Wolverine 72in Skid Steer Tiller (A59000)
NEW Wolverine 72in...
1996 Parker Trailers TravAlong T/A Gooseneck Livestock Trailer (A55787)
1996 Parker...
PALLET OF 12IRON GATES (A58214)
PALLET OF 12IRON...
Commercial Lawn Mower 652R (A56859)
Commercial Lawn...
2013 Infiniti G37 Coupe (A54815)
2013 Infiniti G37...
2015 FORD F-350 XL SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F-350 XL...
