What do I need to make a new garden?
   / What do I need to make a new garden? #21
Plants & vegetables.
NathanatFork said:
Just got my first tractor and Im wanting to have my first garden this spring. Place I want to put it right now is just pasture with thick bahia grass. So, Im starting the area from scratch. Only implement I have right now is a 4' rhino shredder. Definitly going to get a box blade. But, what do I use to get the ground ready to plant the seeds? Ive seen discs and busting plows and tiller and all kinds of stuff. Dont have the $$ to buy it all. So, what implement do I need to get my bare ground ready for gardening? Thanks.
   / What do I need to make a new garden? #22
Tillers are good tools to have...but have a frontend loader also helps alot
   / What do I need to make a new garden? #23
I normaly turn the ground with the 1 bottom moldboard plow, then take the disc to it a couple of times or till all the big clumps are broken up good, normaly this is good enough to plant, which I do by hand, for raised beds on certain plants, I just use the good old tine rake and armstrong labor! I make sure to keep my rows the right width so I can get thru with the tractor and the cultivator to keep weeds down and help with drainage. I started with a larger IH built cub cadet and now use a small Kubota diesel 4wd, but still using sleeve hitch implements on an adapter to the cat 1 hitch. In time I plan to get the larger cat 1 implements, espicaly a disc as the lightweight sleeve disc takes several passes to get what I want done. Watch for used implements in the weeds at dealers, sometimes you can get a really good deal! Best of luck, Mike and Michele T
TAKEUCHI TL8R2 SKID STEER (A51242)
TAKEUCHI TL8R2...
2014 Nissan Maxima Sedan (A50324)
2014 Nissan Maxima...
2017 DODGE RAM 5500 HEAVY DUTY SERVICE TRUCK (A51243)
2017 DODGE RAM...
2024 INGERSOLL RAND IRD25 HYD TRACK DUMPER (A51242)
2024 INGERSOLL...
2019 CATERPILLAR 289D SKID STEER (A51242)
2019 CATERPILLAR...
2013 Chevrolet Traverse LS SUV (A50324)
2013 Chevrolet...
