What do I need to do for the winter months
   / What do I need to do for the winter months #1
rrs26ja
Dutchess County NY
New Holland TC45DA
Hi All,
Over the summer I purchased a TC45. This is my first diesel tractor. What do I have to do for the winter months? The tractor will be used a little for some snow removal but that痴 it. It will stay outside.
   / What do I need to do for the winter months #2
rrs26ja:
Welcome to TBN and the Blue Forum :D! If you purchased your TC45 new and have low hours on it and/or if it was recently serviced and had all the filters and fluids replaced I would mainly worry about your quality of diesel fuel. I was ranting and raving here at TBN all last winter :mad: because of ULSD fuel gelling up without additional additives. I would recommend Power Service (White Bottle) with a double load as recommended on the label. A lot of the TBN members report that the Howes additive is superior to PS as to preventing gelling. I have not yet used this product, but I do intend to if I have any problems this winter. So far my tractor has been able to start and run without difficulty with temperatures around 12 degrees F, but I use my engine block heater as well. Jay
   / What do I need to do for the winter months #3
I'm lucky, I haven't even had to use the glow plugs yet. We've gotten down in the high teens a couple of times when I had to use it and no problems at all starting. Mines a little bigger, a TD95D but still the same basic thing. I did fill up the fuel tank and put in some power service though. I don't have a block heater on it or anything but it's been doing fine so far.
Only thing I noticed was a couple weeks ago when we got some snow the windshield washer reservoir had partially frozen. I put some prestone deicer in it and all is fine now. At least it didn't break anything. I love the heater in this tractor. It will run you out pretty fast when it warms up.
Do check the antifreeze though with a good tester regardless of when or who checked it last. I only trust myself for that test. I've had to fix too many broken blocks before, thankfully none of them mine though.
2018 POLARIS RANGER 570 EFI UTV (A51247)
2018 POLARIS...
(3) CRAFTSMAN MOTORCYCLE JACKS (A51248)
(3) CRAFTSMAN...
2018 E-Z Beever M12R Towable Brush Chipper (A51691)
2018 E-Z Beever...
(2) VISSANI REFRIGERATORS (A51248)
(2) VISSANI...
SPEECO SPLIT MASTER 15 TON PORTABLE WOOD SPLITTER (A51248)
SPEECO SPLIT...
Caterpillar 308E2 CR Midi Excavator (A52377)
Caterpillar 308E2...
