What do I get to mow steep fields [while sitting down]
   / What do I get to mow steep fields [while sitting down] #11
   / What do I get to mow steep fields [while sitting down] #12
I cannot provide pictures of myself in action, and my wife wont watch me when I get on the steep stuff. But I have verified the angles I stated, as I try to be as accurate as possible in all my statements. I give my word that the angles are true, in degrees, and will get some pictures if possible. The only one I have readily available is on a 20 ° slope, in an area I comfortably sidehill.
Ive found that I can climb/descend 45 ー slopes, and sidehill 30 ー. If I cant get on ground with the tractor at those slopes, it isnt going to be useful to me cleared as pasture or hay fields. What can you use ground for thats so steep you cant clear it with your tractor?
You ask a fair question. In fact, last night I asked myself why it's so important to mow those areas. I guess its because they are interspersed with other parts of the field that are easy to mow and they are highly visible from the road -- so maybe its a matter of pride [I like a tidy farm].
Then, after looking at the prices of equipment and considering that I would probably spend more time maintaining it than using it [one mowing a year] I thought about applying the labor versus capital investment algorithm. In short, it would be cheaper and easier to just hire someone to use my DR mower for a day or less than it would for me to do it myself with another piece of machinery in the garage [which is pretty full already]. Not always easy to find someone to reliably do such work but it can be done.
Appreciate your thoughts so far -- additional thoughts are still most welcome.
   / What do I get to mow steep fields [while sitting down] #14
That angle would probably be beyond my max but I learned the hard way. :)
   / What do I get to mow steep fields [while sitting down] #15
Goats? Other than that, I'm inclined to go straight up and straight down or hit the stuff at an angle in multiple passes. Front to back rolls are rare...side to side is unfortunately pretty common.
   / What do I get to mow steep fields [while sitting down] #16
I completely understand wanting a nice clean look. Most of my fields are visible from the road that goes thru our farm, and I like to keep it clean. But some parts Im just going to let grow, too steep or rough to mow. Not worth the risk.
   / What do I get to mow steep fields [while sitting down] #17
Just came I'm from mowing the steepest parts of my fields using my trusty DR Field and Brush Mower. And I have to admit that I'm getting older and that kind of work is getting harder. I can get to most of my fields with my tractor but some of it is just too steep to risk. Even going up and down is tough in some parts due to limited turning/adjusting areas.
A few years back I tried using a flail mower behind my ATV and it was not a success. Aside from the ATV always being in the wrong gear, the lip of the mower would catch on tufts of grass or brush and flip over -- 80 whirling knives in the air punctuated by leaking gas followed by fire, now that's entertainment.
I looked at the Swisher pull behind mower but I'm not sure I can raise the deck enough to clear the stuff in my field. I don't think I've seen a riding mower that goes high enough either.
So I'm looking for your advice on what can take real field mowing conditions [not ball parks] and is least likely to tip over.
That JD 4110 is a nice little tractor. Low center of gravity. The least expensive way to trick it out for mowing steeper hills is rear wheel spacers and two more wheels the same size as what you have now to increase the wheel track width.
Good luck
   / What do I get to mow steep fields [while sitting down] #18
   / What do I get to mow steep fields [while sitting down] #19
It's all about your budget. I have a Steiner that is good on hills, but my Cushman 6150 would run circles around it in steep conditions. With wing decks out at ten feet, it has amazing stability.
   / What do I get to mow steep fields [while sitting down] #20
Extended training wheels may do the job?
RIGID TOOLBOX (A50854)
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2017 Dodge Charger Sedan (A50324)
2017 Dodge Charger...
1999 John Deere 566 Round Baler  Net & Twine, Reliable Performance (A51039)
1999 John Deere...
2017 DRAGON 48' ROLL OFF TRAILER (A50854)
2017 DRAGON 48'...
2015 F-550 Bucket Truck. (A51039)
2015 F-550 Bucket...
