What diesel fuel you using?
   / What diesel fuel you using? #1
Imold
Platinum Member
West Central Mn.
MF GC1705, Cub Cadet RZTL, Husqvarna Rider.
This is my first diesel tractor but I do have two diesel pickups and my question is what fuel are you folks using year round where it gets down to -30* in the winter and 95* in the summer ?
Are you folks just using number 1 or 2 OTR diesel or Non OTR diesel with die being itç—´ cheaper.
I get my fuel at Cenex being their diesel on the regular pump is blended according to the seasons and have yet to have a filter gel up in winter.
Jim.
   / What diesel fuel you using? #2
For my pickup I used the service station treated fuel, when it's getting sub zero I also add more anti gell.
My tractors are on #2 off road fuel till cold weather then additives and one tank is blended fuel about 30-40 percent #1 (kerosene)
with anti-gell additives.
I hope that what ever you use you continue to have no issues with gelling as it will always happen at the worst time possible.
   / What diesel fuel you using? #3
I am just trying to get a fuel shipment. A little nervous about world events. But, at the same time I don't like the fact that I will be getting summer fuel and it may cause issues in the cold.
   / What diesel fuel you using? #4
I use offroad, only difference is the dye, one is on road taxed, the other isn't.. Why pay taxes on the same fuel if you don't have to.. I add antigel in the winter..
   / What diesel fuel you using? #5
The spread in taxation between the two isn't as much here as it used to be.
   / What diesel fuel you using? #6
About 40 cents a gallon here..
   / What diesel fuel you using? #7
Before I got another tank for winter fuel, I kept a 55 gallon drum full of kerosene for winter blending use.
I'd fill the tractor about half full with #2 that had anti-gell added to it then top off with kerosene.
If the forecast was calling for well below zero I'd go heavier with the kerosene.
It usually worked well for me, I can only recall getting bit 2 times in the last 25 years and one of those wasn't a total stoppage
just started losing power and got her home and added more kerosene and a heat lamp to the filter about 20 minutes and she smoothed out and straightened up.
   / What diesel fuel you using? #8
I have some on hand for a few heaters and my steam genny. BUT, already ten years ago the price for kerosene was just crazy high. A 45 gallon drum, I'm sure would bankrupt me!
Out of curiosity, I tried called the gas station that used to sell bulk Kerosene for a current price. No surprise, just another business that doesn't answer a telephone anymore.
   / What diesel fuel you using? #9
It's not cheap, the last I got was $3.25 last year in the winter,
in the summer it was around $2.90 per gallon
Bulk delivery #2 right now is around $2.60,
service station pump price for #2 is $3.09 a gallon
and I saw some kerosene pumps at $3.90 and you had to go inside and sign the book that it wasn't going to be used in a highway vehicle.
   / What diesel fuel you using? #10
I use offroad, treated with Power Service white bottle in Winter.
I use taxed fuel in my truck, also Winter treated.
In this area I don't trust the supplier to treat my fuel. I do that. No worries.
2008 Chevrolet 2500HD (A52377)
2008 Chevrolet...
2005 FREIGHTLINER COLUMBIA SLEEPER (A54313)
2005 FREIGHTLINER...
2015 New Holland Boomer 47 4WD Agricultural Utility Tractor (A53421)
2015 New Holland...
1999 FORD F-450 SUPER DUTY SERVICE TRUCK (A54756)
1999 FORD F-450...
2014 Ford F-150 Ext. Cab 4x4 Pickup Truck (A53422)
2014 Ford F-150...
