WHAT DID YOU DO TODAY ?
   / WHAT DID YOU DO TODAY ? #412
What I am doing today? Well just browsing the interwebs while sitting close to the air conditioner. It's 107 out today. To hot to do much out there. Might do something tonight when it cools off. Not sure though. lol
Chad
   / WHAT DID YOU DO TODAY ? #413
I heard a big crash, and when went outside, I noticed a pile of wood fell over. I was actually relieved, since I immediately thought my removed FEL had toppled instead.
The wood is ash, and is in a stand such that one end of the sticks are three inches away from a block retaining wall, but the other ends are completely exposed. It appears that even that difference in air flow was enough to make the exposed end dry quicker, leaving the wetter ends a larger diameter, causing the pile to topple.
I am on a drug that requires me to avoid the sun, and can cause tendons to rupture in some cases, so I got out briefly, stack a little, come in and make indoor progress, and repeat in a rotation. It's pretty hot out, so it may be the smarter thing even minus the antibiotics.
   / WHAT DID YOU DO TODAY ? #416
Just sat infront of the ac all day.
Chad
   / WHAT DID YOU DO TODAY ? #419
Bush hogged and hauled dirt in an AC cab tractor then took delivery on a tracked skid loader for my son to use for a few days.
   / WHAT DID YOU DO TODAY ? #420
Went back to working on my swamp-crossing project. No pics, sorry. Just a lot of backhoe digging and then ferrying dirt and rocks with the FEL to build a lane across a wet spot about 80 feet long. Still can't decide if I want to put a culvert in soon or build it up a bit more to create a marsh area with water about 18" deep. I might get it a bit more done, then let it sit until next spring so I can see how much water might gather there.
4PC OF PVC PIPE - APPROX. 36" (A58374)
4PC OF PVC PIPE -...
More info coming soon! (A55851)
More info coming...
2016 GENIE S-65 TELESCOPIC BOOM LIFT (A52709)
2016 GENIE S-65...
2006 CATERPILLAR D604S GENERATOR (A58214)
2006 CATERPILLAR...
WICKER BENCH & WEEDEATER MOTOR (A58374)
WICKER BENCH &...
2001 Dorsey DOTS48 48ft 39 Ton T/A Flatbed Trailer (A56858)
2001 Dorsey DOTS48...
