What did you do to your tractor today?
   / What did you do to your tractor today? #1
Skagit
Washington
Massey Ferguson 184-4
Most every forum I'm on has one of these threads and I couldn't find one other than the Power Trac thread so I figured I would start one.
Tore apart the leaking front hub on my 184-4, all the internals look good so I'll get some seals ordered and be back in business. Also figured out why my 4wd wasn't working, broken roll pin was letting front drive line coupler slide back.
Next project is brakes but the 4wd not working was a crisis.
   / What did you do to your tractor today? #2
Grooved rear tires
Topped up gear oil in front axles/differential
Installed PTO shaft for new snow blower
Hooked up cab fan
Got a set of handle type, Cat 2 top link and lifting arm pins
   / What did you do to your tractor today? #3
Cursed it as I loaded on trailer because of a major hydraulic leak…..
   / What did you do to your tractor today? #4
Nothing. It's only a year old.
   / What did you do to your tractor today? #5
Installed a block heater today
   / What did you do to your tractor today? #6
Removed the MMM, since I did the last mow for the season. Tomorrow I hope to install the chains and rear blade for the winter fun.
Cheers,
Mike
   / What did you do to your tractor today? #7
Covered it up because we're going to get sleet and freezing rain.
Why I am sitting here wasting time I guess :)
gg
   / What did you do to your tractor today? #8
I adjsuted the brakes and installed the rear wiper kit on my M7040.
   / What did you do to your tractor today? #9
LOL, plugged it in since it snowed and I'll need to push or blow some away.
And, darn it, it is that wet slushy stuff that wants to clog my blower.
   / What did you do to your tractor today? #10
Of course it's got to be the sticky stuff right off the bat!
22ft Rolloff Flatbed Body (A51691)
22ft Rolloff...
2023 Fat Truck 2.8C Amphibious AWD Off-Road Utility Vehicle (A55852)
2023 Fat Truck...
2000 Ford F-350 Stakebody Flatbed Truck (A51692)
2000 Ford F-350...
Pallet of UV Solid Hardwood Flooring (A53424)
Pallet of UV Solid...
2020 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A56129)
2020 FREIGHTLINER...
JOHN DEERE 6135RW401 MOTOR (A51247)
JOHN DEERE...
