What did you do to or on your Mahindra today?
   / What did you do to or on your Mahindra today? #41
   / What did you do to or on your Mahindra today? #42
Used my Grizzly 72" way beyond it's intended use. With the hydraulic top link I was able to angle the deck and back into some really thick stuff....3-4" sapling....And man was I impressed. That is until I wasn't watching and ate a 6" tree and tweaked the blade carrier slightly and bent the front 8" of the right side deck brace. It isn't bad but there is a bit of a vibration now. Guess I should start saving for the right brush cutter for that kind of work and save my rotary for fields.
That had to suck...... no easy way out for that....$1 part fails, $300 fix, and hours of back breaking work...:(
Tell me about it. Of course I needed the machine today to get some work done. ****** x 2
   / What did you do to or on your Mahindra today? #44
This was on the first day I got the tractor. Had to move a couple of Hickory logs. The second was approx. 30.0 dia. x 12' long and too heavy to lift so I improvised.
   / What did you do to or on your Mahindra today? #45
Went and picked up a couple sections of log for a project my son is working on.
   / What did you do to or on your Mahindra today? #46
Worked on the cottage road today. It keeps getting washed out so my buddy who owns a Kubota L45 with backhoe dug some new ditches and I used the box blade to angle the dirt from the side of the road into the ditch.
In the afternoon we used the tractors to place logs on the sawmill to cut some lumber (Cherry and spruce).
At the end of the day I said, "That was good Canadian day." (It's Canada's 150th birthday today) He suggested that we top it off this evening by going out and shooting some beavers. :)
   / What did you do to or on your Mahindra today? #47
Built and installed chain box for my Max 26XL.1499943817143.jpg1499943839203.jpg
   / What did you do to or on your Mahindra today? #48
We were having some water run off issues where we park our trucks to hunt. It would always run through the parking spots and where we pull in off of the road and make a muddy mess of things. I used the Max26 hoe to dig out a trench, probably only about 50 yards long, to redirect the water elsewhere. Tomorrow will be using the scraper blade to level the parking spots, and then get in some slate to finish things off. It's awesome being self sufficient with my little workhorse.
   / What did you do to or on your Mahindra today? #50
Organized palletized stuff in the barn a bit better. Sorta had an oops in the process and bent the curl-stop tab on my loader.
UNUSED AGT YSRT14 STAND ON SKID STEER (A51243)
UNUSED AGT YSRT14...
2018 CATERPILLAR 299D2 XHP SKID STEER (A51242)
2018 CATERPILLAR...
UNUSED CFG INDUSTRIAL STSD10 QUICK ATTACH SEEDER (A51244)
UNUSED CFG...
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
2012 Ford F-150 Crew Cab Pickup Truck (A50323)
2012 Ford F-150...
2015 FORD F-250XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250XL...
