What did you do on or to your LS Tractor today?
   / What did you do on or to your LS Tractor today? #2,252
We did the same, I added a rubber stall mat cut to size from TSC to the floor, it mad a huge positive difference in foot stability and tool retention.
Great idea. I just plan on using a piece of plywood covered with indoor/outdoor carpet.
   / What did you do on or to your LS Tractor today? #2,253
reclaimed 10-12 ft of yard space on one of our rental properties, then prepped a driveway/park area, loaded and delivered 2 dump trailer loads of asphalt millings to be accompanied by one more in the morning, then will spread them. gotta love that flail mower attachment for clearing these over grown areas
   / What did you do on or to your LS Tractor today? #2,254
Used rear blade to grade my driveway turned out pretty good.
Greased tractor and loader with brandnew grease gun bought from LocknLube not very impressed , the hose is to short, the LocknLube tip doesn’t work worth crap on some of the loader fittings , tomorrow I’m going shopping for a decent standard adjustable grease tip.
   / What did you do on or to your LS Tractor today? #2,255
I have found that locknlube doesn't work well on several fittings, if they are encased in a housing of sorts, it doesn't fit in very well on a lot of them
   / What did you do on or to your LS Tractor today? #2,256
I have posted it on here somewhere, but you need this one. It fits all the zerks on my LS including the backhoe.
Macnaught KY Plus Locking Safety Grease Coupler - Smallest Diameter Bore on Market - 2 Year Warranty
   / What did you do on or to your LS Tractor today? #2,257
Fixed a hydraulic leak at my WR Long third function valve. Thought it was an oring boss fitting. Just by chance after taking it off from the bracket I worked my three point hitch to see if I could confirm the source of the leak. I did. It was coming from the allen screws on the side of the valve body. Tightened them and cleared it right up. I’ve never used the third function valve in the 250 hours of tractor use but all 4 screws had worked themselves loose. I recommend checking them every 100 hours or so.
   / What did you do on or to your LS Tractor today? #2,258
this was yesterday, I did get that driveway/parking area finished
   / What did you do on or to your LS Tractor today? #2,260
^^^^^Nice! You will definitely appreciate a canopy!
72" HYD QUICK ATTACH GRAPPLE (A51406)
72" HYD QUICK...
Pnuematic Transfer Pump on Rolling Cart (A59076)
Pnuematic Transfer...
2017 Mitsubishi Outlander AWD SUV (A56859)
2017 Mitsubishi...
LOT: (2) Kimball Midwest 4-Drawer Hardware Cabinets, (1) 2-Drawer Hardware Cabinet w/Contents & (A59076)
LOT: (2) Kimball...
2008 JOHN DEERE 310SJ BACKHOE (A52709)
2008 JOHN DEERE...
2016 Husqvarna YTA22V46 46in Riding Mower (A56859)
2016 Husqvarna...
