What did you do on or to your LS Tractor today?
   / What did you do on or to your LS Tractor today? #1,001
Didn’t get a pic, but...
Wife managed to slip her scag into the chain link fence. This area is on a slope, still a tad moist, so as zero turns are want to do, when the tires slipped off the edge and into the depression near fence where she week whacks and roundups she was doomed. Being just a 36” the rops doesn’t require much angle to be outside the path.
Unable to manhandle into a better position, LS to the rescue.
Able to get forks over the fence and run a chain from rops to forks. Enough room to lift and inch forward about a foot upslope, enough to be on solid footing to allow driving scag out.
   / What did you do on or to your LS Tractor today? #1,002
My tractor made Photo of the Month on the TBN e-mail newsletter......Woo Hoo!
   / What did you do on or to your LS Tractor today? #1,004
Made the new tractor earn its keep Saturday, pushed all the logs in the photo up onto the burn pile. Next will be the removal of the stumps. I am really impressed with the power this thing has and how much traction it maintains while in sloppy conditions.
   / What did you do on or to your LS Tractor today? #1,005
Definitely looks like you are having a good time! I cannot remember... are your rears loaded? That will make a difference for sure!
Just a heads up..... be careful when you are out moving in that much debris.... the hydraulic filter just under the left floorboard is unprotected, it would be really easy to poke a stick into it! It is one of my spring projects to build some form of removable protection. Glad you are enjoying the tractor!:thumbsup:
Put a bit of time on the power wheelbarrow moving some dirt and firewood. Almost feel guilty since it isn't real tractor time.
At one point I found myself sliding sideways downhill at an angle. Pedal or not made no difference. I knew I wasn't going over as such, but I was moving towards my wood pile and really didn't want to have to call the neighbor to pull me out. No real pucker, just a lot of words unfit for TBN. Got it stopped and corrected enough to back down hill where I could get on less mucky ground (which there is very little of right now) so I could start back uphill in a different direction.
   / What did you do on or to your LS Tractor today? #1,007
Did a little bush hogging today on the mt573, also kinda just wanted to pull something with my new Cummins.
   / What did you do on or to your LS Tractor today? #1,008
Yes I loaded the rear tires definitely worth it. I've been very careful when I've been backing up or around the brush to not drive over it so I don't punch a hole in a tire or get something jammed into that filter. I want to make a skid plate for it but those hard plumbed lines that touch the filter are making me really think about where to attach it. I have no problem making something stout enough just no real connection points. I really want a 3 point connection so I don't stress the side of the cast bell housing. I also want to make a skid plate for the bottom of the tractor but don't want to hinder the ground clearance anymore. The backhoe brackets definitely make the ground clearance a lot less.
I really need to get up to the brush pile with the backhoe to dig in some drainage so I get the water out of where I'm working. The hole where I dug out the stump (about 6' diameter and 3' deep) was filled with water after 1 day. I have a ton of springs coming out my side of the mountain so it is pretty wet most the year with decent soil (until you hit the clay). Hoping I can get the water diverted and I can start making headway on our little runoff pond.
   / What did you do on or to your LS Tractor today? #1,010
Finally got it delivered, still learning to use it, so mostly just had it pose for pictures :D
202482 (A54757)
202482 (A54757)
2000 GMC C7500 ANCHOR DRILLING TRUCK (A58214)
2000 GMC C7500...
telescope boom (A56857)
telescope boom...
2014 INTERNATIONAL DURASTAR 4300 26FT NON CDL BOX TRUCK (A58017)
2014 INTERNATIONAL...
2010 Chevrolet Silverado 1500 (A55973)
2010 Chevrolet...
2022 FORD F-250 (A58214)
2022 FORD F-250...
