What did I do?
   / What did I do? #1
Toddao
jeffersonville VT
GC2410TLB
2009 MF2410 so I am pushing some snow this morning and the tach cable is screaming, I shut it off and it is fine , does it again , so I bring it in and remove cable , I was going to leave it off, BUT, In doing so I thing it hit the cluster board or shorted something, as it would not start? So I jump it at the started it runs, but no Gage's function , yes I checked all levers and switches . Thanks for any advise
Happy thanksgiving
   / What did I do? #2
There are some fuses near the battery.
I would also look for broken, or burned connections in the area you were working.
   / What did I do?
I checked all the fuses in the fuse box and didn't see any broken wires, that is what has me confused, unless the cable wiped around and hit the back of the cluster circuit board?
   / What did I do? #4
Check and see if you have a main fuse at the starter.
   / What did I do?
Double checked all fuses and found a bad one, 10 amp for the turn signal , it didn't look bad the first time I looked at tit. I took my time and thankfully it was only a fuse
   / What did I do? #6
I learned a long time ago, to put a test light on them, looks can be deceiving.
With the plastic fuses, it's really easy to turn on the power, and touch a grounded test light to both the 2 terminals on the top. If the light does not light on both sides, the fuse is blown.
In an automotive fuse box this is actually faster then pulling them, and looking at them.
Glad you got it working. :thumbsup:
City of Buckhannon Onan 200 Set Stand By Generator (A52384)
City of Buckhannon...
2023 Yamaha R Max XTR  (A52384)
2023 Yamaha R Max...
UNUSED KIVEL 3500# PALLET FORKS (A51248)
UNUSED KIVEL 3500#...
2025 SDLANCH SDLE20 UNUSED Mini Excavator (A53117)
2025 SDLANCH...
(2) COLUMN PROTECTORS (A51248)
(2) COLUMN...
