What did I do?
/ What did I do? #1
MissouriSprayer
Missouri
John Deere 4720 cab
Today I used my gas powered power washer and did a bunch of work. It ran like a top...its a Honda powered generac. After I was done I tipped it on about a 45 degree angle and supported it so I could unhook the supply hose. I should have set it back down but as it happens i went on with shop cleaning. About 2 hours later I went out and saw it and was going to put it back in the shop. When I tipped it back level, oil ran out of the air cleaner. So, after too long a day and under orders to come eat dinner I left the little bugger till tomorrow.
So wise friends....what did I do to my motor and what should I look forward to tomorrow?
/ What did I do? #2
You probably just got crankcase oil into the air cleaner. Check the air cleaner, replace if needed, check the oil level, and fire it up. Be prepared for some smoke for a minute or two, then relax.
/ What did I do? #3
I would crank a few revolutions it with the spark plug removed.
/ What did I do? #4
Check the oil level in the crankcase. It should not be above the full mark. Remove the air filter. If it has oil on it, replace it. Clean all the oil from the air box-where the filter goes-and install the new filter. Remove the spark plug and give it a few pulls. Replace the spark plug and start it. It may smoke a little but should clean out. Best wishes. I have a Titan Commercial gas powered pressure washer with a B&S engine.
2026 SDLANCH SDLC1220 High-End Carport (A64194)
2026 SDLANCH...
MASSEY FERGUSON 28 BLADE DISC HARROW (A64278)
MASSEY FERGUSON 28...
2017 Nissan Altima Sedan (A64557)
2017 Nissan Altima...
2018 International WorkStar 7300 2,000 Gallon Water Truck (A64556)
2018 International...
2017 VERMEER TG7000 TUB GRINDER (A66091)
2017 VERMEER...
2020 CATERPILLAR 279D3 SKID STEER (A65053)
2020 CATERPILLAR...
