What could have caused this ???
   / What could have caused this ??? #62
Be careful what you tell your insurance company. Certain parts of my coverage exclude wind damage. I had a microburst-like incident several years ago that uprooted a large china berry tree which crushed one of my vehicles. The lady on the phone said I'm not covered for wind damage. I told her it wasn't the wind that crushed my car. It was tree damage.
If the microburst story holds true in your situation, that would be 100% wind damage. But you might be covered for wind, but check your policy first.
DON'T TELL 'EM ANYTHING except "My roof is damaged and needs repair/replacement. No idea what happened - send your adjuster and checkbook." They record all calls (IME) so don't volunteer information - you're not an expert, you're a policy holder.
   / What could have caused this ??? #63
Microbursts can be wet or dry, but they’re only associated with thunderstorms.
If the damage was due to impact from a falling object there would be more broken tiles and the damage wouldn’t be spread out over the length of the roof.
I think that the most likely explanation is a dust devil. The atmospheric conditions were right and they can be just tens of feet in diameter, causing very localized damage.
A dust devil would certainly be a contender. I flew frequently back and forth from Sierra Vista to El Paso back in the mid 70's. In the summertime dust devils were very common. On clear days with unlimited visibility multiple dust devils could be seen. Some would rise hundreds of feet above the desert floor.
   / What could have caused this ??? #64
Was this reported to local authorities to see if anyone else had reported anything? Also I’d consider the local TV news station, they are always looking for something unusual and might turn up an answer.
   / What could have caused this ??? #65
Lived in San Tan Valley Az for close to 20 years. Had the same thing happen in 2015 or so. Not the middle of the roof though. Blew all the edge tiles off on one corner of the roof. Which sucked because a bunch broke and no one made the color anymore. Had to go to a roof tile grave yard (had no idea they even existed) Got some really close.
   / What could have caused this ??? #67
Have you noticed an increase or a decrease in your local roadrunner population? Are you finding random wooden crates with ACME stencils on them laying around? 😁
   / What could have caused this ??? #68
This one made me laugh!!! 👍
   / What could have caused this ??? #69
What I hate here in my part of Alabama in the summer they have Department of Transportation Tractors that are counterweighted on one side and on the other side they have a Bush Hog turned vertical and they drive down the road cutting tree branches. The stop chains are also vertical at this time too. Throws wood out all sides, but I know of no damage ever happening YET ! Once was walking on my daily route and a family hired a guy with a Skid Steer with a forestry mulcher on the front and he threw a large limb out of the front and I had to take a few steps avoiding the spinning pine branch coming my way. Not a Happy Camper for sure ! Doubt this get a roof, but a windshield would be a for sure guess.
   / What could have caused this ??? #70
Are you sure it wasn't an illegal that came across the border
loaded with beans and let one fly :ROFLMAO:
willy
   / What could have caused this ??? #71
So obvious I'm surprised nobody thought of it earlier. Smack myself in the forehead.:geek:
   / What could have caused this ??? #72
Were any jets flying overhead when this happened? I've seen similar damage while I was a roofing contractor, now retired. Turned out to be a chunk of blue ice. You should see what that stuff does to a slate roof. If so the airport can tell what plane was flying over and the airline will be responsible for all repair costs.
   / What could have caused this ??? #73
If you listen to most news media they will tell you that was caused by climate change and internal combustion engines. And maybe a touch of covid.
Actually, what you posted is demonstrably false.
My county does this too. Bush Hogs type rotary cutters in the vertical trimming tree branches. But maybe the drivers operating these are more observant because they always stop trimming whenever I drive by. Granted, I never just blast by these roadside operations, I always give them plenty of room whenever I need to pass them on our two lane roads, just common courtesy. But they all seem to watch out for passing traffic and more than once I have heard the rotary cutter winding down as I drove past.
Well, the roof has been repaired. They did a good job and have a 2 yr warranty. Cost was $4200.
The cause was definitively a high wind occurrence, yet no thunderstorms or other bc weather was clear blue skies w only high cirrus clouds. The underpinning felt paper and plywood was completely undamaged. No other house in the perimeter of his was affected, other than excessive debris blown in their pools.
Pretty bizarre to say the least, but if the X-Files ever starts up again, here’s the material for an episode.
Hope everyone is doing well. Send some rains our way.,
   / What could have caused this ??? #75
Thanks for the update bro! ☮️✌🏻
   / What could have caused this ??? #77
About 10 years ago I was in the sauna change room looking out the window and I saw something strange. A dust devil came from the west, encircled the old red garage, picked up and bent some roof tins on both sides. I could see through the roof when the tins were picked up.
Dust was swirling around the garage for maybe 30 seconds and then it moved away.
If I hadn't seen it, I wouldn't have had any idea of what happened.
2019 MACK PINNACLE (A55745)
2019 MACK PINNACLE...
Adams 5 Ton Spreader (A56438)
Adams 5 Ton...
John Deere 855DXUV Gator (A57148)
John Deere 855DXUV...
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
1986 Ford LNT9000 Dump Truck (A56438)
1986 Ford LNT9000...
