what compaires to JD 3120 or 3320 tactor??
   / what compaires to JD 3120 or 3320 tactor?? #1
cavesrus
im tring ot apple to apple comp to the JD 3120 or 3320 and i thought it was L 2800 but now im not to sure what do you think i should look at in kub comp to them Thanks for help Aaron
   / what compaires to JD 3120 or 3320 tactor?? #3
Their is not really a direct comparison. The b3030 has the bells and whistles and hp, but on a lighter frame. Their front end loader will have a little less lift and 3pt as well. The lighter weight makes them a better choice for mowing. The other range to look at is the grand L series. The L3130 is a slightly bigger heavier tractor with a much stronger front end loader and more lift capacity in 3pt hitch. Cost wise the JD 3320 is comparable to the L3130 and the b3030 a fair bit less than the JD 3120.
What are your primary applications?
   / what compaires to JD 3120 or 3320 tactor?? #4
   / what compaires to JD 3120 or 3320 tactor?? #5
As was mentioned, there is no exact match, but I cross shopped the JD3120/3320 to the Kubota B3030 and L3400. You can see what I ended up with.
   / what compaires to JD 3120 or 3320 tactor?? #6
dirt work and mowing and small garden i have 12 arces and FEL will be use to pick up trash shingle from the roofing company i own etc. i like the JD weight and fit the 3030 seems a lot littler i liek the grand but heck they boys are $$$$$ about 3k higher than the JD etc.
   / what compaires to JD 3120 or 3320 tactor?? #9
I'm sorry to play ignorant,Dont understand your post
Your saying the 3130 is 3 grand more than JD 3320 ???
   / what compaires to JD 3120 or 3320 tactor?? #10
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2013 Nissan Rogue S SUV (A50324)
2013 Nissan Rogue...
2020 Bobcat S850 Skidloader (RIDE AND DRIVE) (A50774)
2020 Bobcat S850...
2013 International Day Cab Semi (A50120)
2013 International...
2013 Nissan Juke SUV (A50324)
2013 Nissan Juke...
2012 Cat 272C Skidloader (RIDE AND DRIVE) (A50774)
2012 Cat 272C...
