What cha think of this? Grapple..
   / What cha think of this? Grapple.. #21
I've seen linear actuators in Surplus Center's catalogs. I think they would have plenty of uses; but a grapple is not one of them.
   / What cha think of this? Grapple.. #22
Electric actuators have come a long way. They are capable of huge loads, 16 tons is what I'm familiar with. These actuators are replacing hydraulic actuators for demanding tasks like the motion bases of full-motion flight simulators. In the attached PDF file link, you can see the side-by-side photos of an electric system beside a hydraulic system. The hydraulic system has huge electric motor driven hydraulic pumps (normally below ground level), plumbing, and large accumulators to provide instantaneous response. The electrical systems use 1/4 of the power and require little infrastructure. This allows for quick installation of the motion base and easy access for maintenance. It also ensures that there will not be the inevitable hydraulic fluid floods associated with a failure of a hydraulic line.
CAE Electric Motion System
Having said this, I think the environment for a grapple is much better suited to hydraulics. A hydraulic cylinder piped to the tractor's existing hydraulics would be much more reliable in my opinion. Mechanical gears and jackscrews of small electrical actuators are prone to problems. By comparison, the average hydraulic cylinder's operation is much simpler. It also does not have the ability to short out and cause electrical problems. I just don't think a tractor's electrical system is designed with these types of loads in mind; whereas, the hydraulic system certainly is.
   / What cha think of this? Grapple.. #23
We use these electric actuators in Theme park rides. Problem is the juice. You need lots of it. Response time is amazing and failure is reduced, especially important when it is about as many butts in the seats as you can get. They don't look delicate, but have not seen them in an industrial (dirty) application.
CATERPILLAR H90C HYD HAMMER (A52707)
CATERPILLAR H90C...
2015 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A53422)
2015 Chevrolet...
2010 Turfco Mete-R-Matic III Pull-Behind Top Dresser (A55851)
2010 Turfco...
UNUSED WOLVERINE TQH-26-01C 3 PT QUICK HITCH (A57193)
UNUSED WOLVERINE...
1999 Kubota L2500D Utility Loader Tractor (A55851)
1999 Kubota L2500D...
UNUSED FUTURE 24" HYD TILT EXCAVATOR BUCKET (A57193)
UNUSED FUTURE 24"...
