What causes leak-off lines to leak?
   / What causes leak-off lines to leak? #1
MA1920
Central MA
Ford 1920
Yesterday after using the tractor, Ford 1920, I noticed a smell of fuel and one of the the leak-off lines was leaking. It seemed to be leaking where the spring clamp goes over the tubing, so maybe it's a case of the tubing being worn.
What are the leak-off lines for? Could the leak indicate a more serious problem somewhere in the fuel delivery system?
Thanks for any guidance.
Bob
   / What causes leak-off lines to leak? #2
Are you taling about the excess fuel return line?
Soundguy
Soundguy, according to my owner's manual and Ford service manual for the 1920, they call it a leak-off line. Off of each injector, there is a "j" shaped line that goes to a fitting; and a piece of rubber tubing goes from fitting to fitting and dead ends at the injector at the front of the engine. Hope that makes sense. Basically, you're probably right.
What would cause the line to have excess fuel in it?
Bob
   / What causes leak-off lines to leak? #4
I don't have my 1920 anymore.. but will try to dig thru my old paperwork. Hopefully someone else will chime in in the meantime.
Soundguy
I appreciate the effort Soundguy. On a side note, what did you think of your 1920? Anything I should look out for? Thank you.
Bob
   / What causes leak-off lines to leak? #6
Awesome tractor.. did everything I ever asked for it.. Including pulling a set of disc's too big for it to disc up 10ac of my pasture a few times.
Sips fuel.. powerfull enough for a 6' mower.. mine had 4wd and 12x9 tranny.. started first time every time.
All I ever did to it was fluid / filter changes and a battery when it was 4 years old.
Ended up trading it back to the dealer i bought it from to get my 7610s... ( should have kept the 1920 anyway... but... )
Soundguy
Soundguy, thought you might be interested in an update. I replaced the rubber hose and the leak is gone.
27031 (A51692)
27031 (A51692)
Toro Workman Utility Cart (A51694)
Toro Workman...
2012 FORD F-250 XL SUPER DUTY (A52472)
2012 FORD F-250 XL...
2013 Crane Carrier Co. Low Entry Loadmaster Excel-S 25 Yard Rear Loader Garbage Truck (A51692)
2013 Crane Carrier...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
