What can you mix with top soil to give it more drainage
   / What can you mix with top soil to give it more drainage #2
You've posed a question suitable for a professional soil scientist... But even such a person would have to ask first what kind of top soil you have. Topsoil in the various regions of the nation is quite different in character and compaction. If you have a small area involved, you can actually go to a home improvement store or nursery and buy a bag of material they pretty-much guarantee to make your soil drain better.
I suggest talking to gardeners and nurserymen in your area... And you can also send a soil sample to your extension service as a place to start. Remember that, to drain, soil must have some place for the water to drain to. Wonderful soil over a bowl of clay will be soggy and will not drain.
I have heard of sand being used, and mulches and such... But it would all depend on the kind of soil you have right now.
   / What can you mix with top soil to give it more drainage #3
Lime can make clay soils more workable which may help with drainage. If you use sand, use the real coarse type to keep it from hardening.
   / What can you mix with top soil to give it more drainage #4
Sand is a good thing , makes for a smooth ride also . No foam in the bud .
   / What can you mix with top soil to give it more drainage #6
When I lived in Maryland GYPSUM was recommended for making the local blue clay more friable. Worked well in my raised bed vegetable and flower gardens.
Wood chips have the advantage of adding organic material. In this part of Florida, where lime rock is quarried and we have hight pH {low acid} soil conditions, pine bark and pine chips, which are acid, are often worked into the soil, which increase the pH and make soil more friable and water retentive. We have a lot of forestry industry here; chips are readily available by the truckload.
In most of Georgia you have red clay, which I speculate is acid. Point being, if you consider wood chips research the characteristics of the chips available to optimize your results in the soil.
You may need to add some nitrogen fertilizer when incorporating woods chips. Here, with our sun, heat and humidity, I do not add nitrogen.
   / What can you mix with top soil to give it more drainage #7
Spray soap/surfactant, Agri-SC or Panhandler.
   / What can you mix with top soil to give it more drainage #8
I have heard that before, that some farmers pour cheap soap such as Octogon brand over their soybeans before planting. Helps soften the dirt around the seed tospeed up root development.
   / What can you mix with top soil to give it more drainage #10
Depending on what part of GA you're in, and how big an area we're talking about, you might want to take a look at rice hulls. If you're within a reasonable delivery distance of the delta rice fields, they're relatively cheap. Once tilled in they create porosity in the soil and add organic matter as they break down. I put them in my raised beds every spring. I also use them as bedding in my chicken coop, and the cleanings after a couple months are just about the best soil amendment I've ever used.
2012 Ford F-250 Ext. Cab Service Truck (A50323)
2012 Ford F-250...
2022 CATERPILLAR 259D3 SKID STEER (A51242)
2022 CATERPILLAR...
2011 FREIGHTLINER M2 TANDEM AXLE FLATBED TRUCK (A51222)
2011 FREIGHTLINER...
1989 Freightliner FLD120 (NEW CAT 3406A, NEW REAR ENDS, CLUTCH) (A50397)
1989 Freightliner...
2015 KUBOTA 1140CRX RTV (A51406)
2015 KUBOTA...
2016 FREIGHTLINER M2 DAY CAB (A51222)
2016 FREIGHTLINER...
