PineRidge
Super Member
Have no experience with plasma cutters whatsoever so really need to draw off the TBN collective knowledge base. I like to ask lots of questions and do my homework before making any purchase.
Curious as to how much control one might have when freehand cutting 3/8 to 1/2 plate steel while working with a plasma cutter. What quality of cut should one expect, will cut edges still need to be dressed with an angle grinder to make them look presentable or will they look rough like an oxyacetylene torch cut?
Is a welding helmet required for plasma cutting?
Can a plywood template be followed with a plasma torch tip without setting the template or worse on fire?
What size machine would be the proper size for cutting 3/8 to 1/2 steel in a 220 volt model?
Are some machines cheaper to operate as far as consumables? What are consumables and why are they used up by the machine?
Are plasma cutters rugged? I mean I have had an old Lincoln buzz box for 20 years and if plasma lasted half as long it might be easier for me to justify the cost of one.
How long should one be able to still purchase consumables before the style of the machine is obsoleted?
Thanks for being patient with my many questions.
