What can I use to pick small rocks out of dirt?
   / What can I use to pick small rocks out of dirt? #13
Harley rake
   / What can I use to pick small rocks out of dirt? #14
After plowing to loosen up the soil, a disc works well to expose large rocks that you can remove by hand (if it is an acre or two). After the large rocks >6" are removed, my rototiller does a good job of breaking up sod and exposing rocks >2". If the soil is dry enough and there is little sod clumps left, then my rock bucket, while slow, will remove >2" rocks without retaining too much soil.
At this point both the disc and the tiller has a tendency to bury rocks less than 1-2" and the seed bed looks nice. However, if I run over the seed bed at this point with a chain harrow (either the chain side or the aggressive side with tangs down), it will bring the small rocks back up to the surface. I borrowed a harley rake and while it can windrow small rocks fairly quickly on the surface of compact soil , with loose soil I wasn't that impressed. A lot of soil was mixed with the windrowed rocks that I removed with the loader. Might have been my technique, who knows.
When I removed a small gravel parking space and converted it to a deep flower bed I went with screening the soil as most implements only removed surface (1" deep or less) rocks. I box bladed off the top layer of gravel. Dropped the rippers and loosened the soil (glacial sand / gravel with a little loam on top), rototilled it to make it easier to move and screened out all the rock > 0.5" using a frame covered with 1/2" hardware cloth and angled at 45 degrees.
If I had a large amount of soil to screen I'd try to rent one of the commercial screeners like a DeSite SLG-78 portable topsoil and rock screener or contemplate purchasing and then selling when done. They have a variety of screen sizes and options.
If you have real rocky soil, define a small rock as 2", and have lots of acreage, then a real rock picking implement like a Rite Way rock picker or a Rock-eze would be the way to go. Around here used ones show up at auction for $2k-6k and in need of some welding. They are amazing to watch in action and appreciate if you have been picking rocks by hand for years ...
   / What can I use to pick small rocks out of dirt? #16
I am building an immitation "Flip Screen" (Google It). I have all the parts, but the guy doing the Solid Works stuff is taking forever.
   / What can I use to pick small rocks out of dirt? #17
Was just looking at those on youtube, and was wondering how hard it would be to make one. Would be very handy...
   / What can I use to pick small rocks out of dirt? #18
Something like this should work Landscape Rake for Compact Tractors
There are lots of brand and models out there and I think TSC has one.
I built my own rock screen by wrapping chain link fence around my pallet forks and just shoveling the piles I had made around the yard through it. My drag harrow also does a good job bringing them to the surface. I then waited until after a rain and went out rock picking, but I was looking for stuff larger than 2"
   / What can I use to pick small rocks out of dirt? #19
Here is a pic that popped up on google for a rock picker- off TBN.
http://www.tractorbynet.com/forums/...d1432650832-rock-picker-5981668_36l0ewtsq-jpg
   / What can I use to pick small rocks out of dirt? #20
If you dirt is loose or can be made loose, so it can be sifted, something like a beach cleaner may work.
Large and small, complicated and simple ones:
beach cleaner - Google Search
Bruce
2015 Chevrolet Express Passenger Bus (A50323)
2015 Chevrolet...
2017 Freightliner M2 106 24FT Box Truck (A50323)
2017 Freightliner...
SAKAI SV510 SMOOTH DRUM ROLLER (A51242)
SAKAI SV510 SMOOTH...
CATERPILLAR 242D WHEELED SKID STEER (A51242)
CATERPILLAR 242D...
2005 Sterling Acterra Tender Truck (A52128)
2005 Sterling...
Great Plains Grain Drill (A50515)
Great Plains Grain...
