Mowing What can I do ??
   / What can I do ?? #1
ILUVOZ
Krambach NSW Australia
Ford 4110 has GONE!! !! NEW HOLLAND TD 70 TD PLUSS is Now Here !@!
IMG_1071.jpgI have a TD 70 D and am trying to slash and clear ground that hasn't been touched in 15 years , so the bracken and Tobacco weed and all the other crap is taller than my tractor ! ( thank heavens for the enclosed cab! )
am I asking too much of the unit for this work ?? should I get someone with a dozer in to clear it all before I slash ?? ( its a pretty good slasher ! mind you )
I do scare myself when pushing through bush that totally coves the windscreen adn I have NO visibility forward.. but what the heck.. I Plow on anyway..
   / What can I do ?? #2
Naturally, this just my opinion, but as long as you don't exceed the cutting limits of your mower, and you keep the grill cleared off sufficiently (to avoid overheating), and you don't mind the tractor paint getting scratched up, then I think you are ok, providing you go slow. No visibility can raise the pucker factor some, but if it gets too bad, then you could always try mowing in reverse and let the mower knock everything down first. That would give you a little extra visibility. Normally you would like to walk the property first to check for hidden metal objects, hidden ditches/holes/stumps/etc, but it doesn't look possible in your case. That's some tall, thick brush you are dealing with!! Another picture with the tractor in place against the brush you are mowing would help give the audience a better perspective of just how tall it is. Good luck.
   / What can I do ?? #3
I'm doing the same thing on an 18 yr field. I put the bucket at about knee height, go slow until I hit one of the trees too big to knock down, back up go around. If I can knock it over, my 5ft Fred Cain cutter will chop it up.
Some of the bigger stuff gets knocked down too if I work at it. I've been knocking the over and using the bucket and momentum to get the root ball out then push it a a pile in the middle or to the side and come back to move it when I have made more room.
I've already snapped one work light off my brand new machine...... Mirrors are not very happy either. I'm going to remove them this morning.
   / What can I do ?? #4
I agree, no problem. I was amazed at what my brush hog would cut.
   / What can I do ?? #5
As mentioned, hard to say without a bit more perspective, but my sons and I have cut a lot of brush that looks similar to that over the years, so it can be done. However the last time we did a big field, we rented a tracked skid loader with an enclosed cab to do a lot of it along with our M8540 and Woods DS1260.
The brush was over our tractor and certainly over the skid loader, so we scouted a lot of it before hand and as we progressed, I still almost lost the tractor in a washout and had to use the FEL to get back out, it would have swallowed the loader, so go slow and be careful.
   / What can I do ?? #6
I have cut trees with a bush hog that were the size of a soft ball with a 35 hp ford. Had to be careful to run over the one at a time so they did not lift the tractor off the ground. I am not joking. I would try to keep working edges and corners, so you can keep tractor repairs down.
   / What can I do ?? #7
You might want to take a look at a topographical map and if possible talk to folks who know the lay of the land...you don't want to drive off a cliff or into a deep gully....Go very slow...Good Luck
   / What can I do ??
Buckett??? LOL// oops.. Np Bucket!
   / What can I do ?? #9
Or even a stump or big rock.
   / What can I do ??
The shots I have added are the before and after shots of where I have been crashing through the brush..
I am going very slowly and trying very hard to IMG_1078.jpgavoid the nasty drops and big rocks!
2014 JOHN DEERE 17D EXCAVATOR (A51242)
2014 JOHN DEERE...
2013 INTERNATIONAL MA065 CAB AND CHASSIS (A52472)
2013 INTERNATIONAL...
2018 Ford F-350 Crew Cab Pickup Truck (A50323)
2018 Ford F-350...
2011 Chevy Avalanche (A50324)
2011 Chevy...
Ford 641 Workmaster (A50514)
Ford 641...
1271 (A50490)
1271 (A50490)
