Rear Blade What can a rear blade do for me that my box blade can't? Road and ditches mainly
   / What can a rear blade do for me that my box blade can't? Road and ditches mainly #71
Well it makes me think that my 6500lb tractor would be okay with a 850lb 8' blade. I think that's what I'll buy.
My 3800 lb L4330 does just fine with my 8' EA rear grader blade. That size tractor, there's no way I'd buy a 7'er.
That's what I would do. If the length turns out to be just too much, you can always shorten the 8 footer. Since your tractor can handle weight, I would also lean toward the heaviest blade. Do all the blades you listed have the same shape & thickness? That's something to check. Also, do consider the end caps - they are perfect for jobs where you are trying to smooth using existing material rather than just cut & move the dirt off to the side. Caps are useless in snow, but they unbolt for winter.
rScotty
The land pride is 5/16" and most the others are 3/8" but the land pride also has full box support all the way across the blade with 3/16", so it looks stouter to me. I have some of that info in my comparison matrix up a few posts back.
That's the moldboard that I described. They all look to have 1/2" blades.
So basically this thread has served to grow me out of buying this standard implement for $1250:
And put me into a heavy duty 8' three cylinder heavy duty rbt4096 blade with a diverter valve.
On monthly payments at zero interest.:rolleyes:
Thanks for all the advice. I'll get the sideplates, shoes, and gauge wheel as I need them in the future. This thing was already $4390 like it sits with tax included and the diverter valve.
   / What can a rear blade do for me that my box blade can't? Road and ditches mainly #74
Hey that's what we are here for! I think you will be much happier instead of thinking, woulda, shoulda, coulda.
   / What can a rear blade do for me that my box blade can't? Road and ditches mainly #75
Sweet!
   / What can a rear blade do for me that my box blade can't? Road and ditches mainly #76
Thanks. 7' would cover my tracks in the straight form. It wouldn't at an angle. Is that what you're referring to?
Yes. I seldom run my rear blade in a flat profile to my tractor. It is almost always set to 30 or 45 degrees when in use. I would never consider a blade that did not cover my tractors at 45 degrees when centered behind the tractor. I would consider on wide enough centered to cover tracks that could be offset for special purposes (cleaning out or digging ditches).
Here is the manual diverter valve setup so my two rear remotes will move three cylinders. They said that I should be able to reach the handle from my seat.
   / What can a rear blade do for me that my box blade can't? Road and ditches mainly #78
You can't reach that from your seat.
   / What can a rear blade do for me that my box blade can't? Road and ditches mainly #79
Electric diverters are fairly simple to wire up and handy to use.
   / What can a rear blade do for me that my box blade can't? Road and ditches mainly #80
Exactly. A good option for many uses where constant control is not a necessary. I had planned on using one to power a grapple and though it can be done it is not very efficient for me. But on a rear blade, it would be a good way to go.
2015 Hyundai Sonata Hybrid Sedan (A53424)
2015 Hyundai...
toro turf sweeper (A50324)
toro turf sweeper...
2012 NEW HOLLAND BOOMER 3045 COMPACT TRACTOR WITH 250TL LOADER (TRANSMISSION ISSUES) (A55314)
2012 NEW HOLLAND...
2006 INTERNATIONAL DURASTAR 4300 (INOPERABLE) (A55745)
2006 INTERNATIONAL...
2016 FORD F-250 PICKUP TRUCK (A52576)
2016 FORD F-250...
