Rotary Cutter what brand is this Rotary Cutter?
   / what brand is this Rotary Cutter? #11
Hi All, I'm new to the forum and have a rotary cutter I need to repair. Does anyone know what brand this is?
   / what brand is this Rotary Cutter? #12
I don't just pump grease in it. Grease will not ever mix with oil if it's just pumped in. Cut off an oil can and mix gear oil and pump grease together and then put in gear box. Gear boxes have a side plug on them and that's the oil level. Make sure the vent is open too. If the vent is not open it will push oil out when it warms and expands. Too much oil and it will push oil out. I just bought stump jumper for a rhino 6' with a 110 hp gear box for $500. Changed it right out. Just loosen bottom castle nut and put cottter key back in and go cut a little bit. It will be loose. Then take it off if you need to. Never Seize is your friend. But make sure it needs to be removed. Make sure oil level is correct and vent is open. If you don't check those easy checkable things, a whole stack of seals will not fix it.
   / what brand is this Rotary Cutter? #13
I worked at a tractor dealership mechanicing. When people came in with them shear bolts them parts boys were what brand is it? Do you have the old one? They'd get out their calipers and measuring tapes and look so official. Knowing they were going to the bolt bin to get a 42 cent bolt to sell for 25 dollars. Customer would ask about the nut. Oh, nuts are 8 dollars, figured you would use your old one to save money. Customer would leave feeling good with his 25 dollar cheap no grade bolt from the grab box. I guess it's all in perception.
2006 Imperial 14Ft Flatbed T/A Equipment Trailer (A50324)
2006 Imperial 14Ft...
2006 APPA TL (A55788)
ASSET DESCRIPTIONS & CONDITION (A56138)
ASSET DESCRIPTIONS...
ST225/75R15 Trailer Tires (A55788)
ST225/75R15...
2021 JOHN DEERE 7R230 LOT NUMBER 204 (A53084)
2021 JOHN DEERE...
John Deere 1025R (A53317)
John Deere 1025R...
