What brand 15ft. Rotary Cutter to purchase?
   / What brand 15ft. Rotary Cutter to purchase? #1
Pat Martens
1973 John Deere
I am in the market for a 15ft. heavy duty rotary cutter (brush cutter) to cut heavy sprouts, etc. on my ranch in Oklahoma.
Could someone offer some advice as to what brand is best? Most rugged, less likely to break down, something NOT to buy?
Thanks,
Pat Martens
   / What brand 15ft. Rotary Cutter to purchase? #2
Pat,
Check out the Kodiak. I've got a 10' pull type and small pine trees 3 to 4" diameter didn't stand a chance with this unit. Kodiak has a 15'er you're looking for.
Warren
Thanks, I haven't heard of that brand name, but I will do some checking to see if they are available in Oklahoma. Since they are expensive, I'm sure going to do my research before I buy.
Pat
   / What brand 15ft. Rotary Cutter to purchase? #4
go with the bushhog batwing shredder an get the heavy duty cutter.with that you can cut brush 3in thick.the batwing will cost you $15,000 more or less.
   / What brand 15ft. Rotary Cutter to purchase? #5
Thanks,
Pat Martens
i can send you info and specs but the Modern-Ag 15 footer is the way to go. it is heavy duty (7 gauge steel) plus it is galvanized. Big gearboxes and cuts great. 5 year gearbox warranty and 10 year rust warranty. Made in Beaumont Texas. Very rugged, no problems, a new one will run you $12,250
   / What brand 15ft. Rotary Cutter to purchase? #6
If you will ever need to resale BushHog would be the easiest, LandPride, JD, and Rhino make good units as well.
   / What brand 15ft. Rotary Cutter to purchase? #7
Also check out the BushWacker T180. Verry heavy built batwing.:thumbsup:
   / What brand 15ft. Rotary Cutter to purchase? #8
Woods 1800 is a real tough unit, the guys who farm our land own a couple and have not had any trouble with them. We own a Woods 10 DS1260 and have used it hard but have only had it two years.
   / What brand 15ft. Rotary Cutter to purchase? #9
Thanks,
Pat Martens
Do you have the PTO Hp to drive it? At 5 hp / foot you will need 75 hp minimum. That means a big tractor with a 100 hp engine.
   / What brand 15ft. Rotary Cutter to purchase? #10
what makes you so sure that modern is a top- of the line shredder when all they are is a renamed mowhawk shredder.mowhawk had the same warranty on the gearboxes as modern.my mowhawk shredder is 15 yr old peice of junk.it shatter all the U joints just doing easy shredding not even running hard.had to put 3 new gearboxes on it at 2wks old or less because the dealer didnt check an service the gearboxes.now all i have is junk iron.i shouldve bought a 10ft brushhogg from the beginning.but my buddy would not come off $300 so i ended up buying a peice of junk.
2021 HAMM HD+9I VO SMOOTH DOUBLE DRUM ROLLER (A52706)
2021 HAMM HD+9I VO...
2004 PROCO 130BBL VACUUM (A53843)
2004 PROCO 130BBL...
1270 (A50490)
1270 (A50490)
2015 TAKEUCHI TL10 SKID STEER (A52705)
2015 TAKEUCHI TL10...
2022 Ford F-250 XL 4x4 Ext. Cab Pickup Truck (A52377)
2022 Ford F-250 XL...
