Spreader What belt is this ?
   / What belt is this ? #1
BertZegers
South-West Ontario
Kubota L2900, Zetor 8011, Kubota KX41Excavator, John Deere 4400 Combine, Case 1816C skidsteer
I have an International Harvester 103 manure spreader on which the belt is about to break.
I tried to find the part number, but no luck so far. Messicks has the IH 103 on file, but the belt is not listed.
I can measure the length of the old belt, but I think it has the wrong width and profile.
Does anyone have access to the Case database?
   / What belt is this ? #3
I checked Case/IH, and it shows the same thing as Messicks. I've also fired off the, I think 6th complaint letter, as to their revamping their parts site. Seems it would have been a lot simpler to put N/A after parts they don't handle anymore, then to go through and remove them. So a person could at least find and aftermarket alternative. I realize it's all about the buck, but doesn't say much for customer loyalty, that got them where they are.
Since they did this, I've started searching, and buying hard copy parts manuals, OEM if I can. Some reprints I've seen have poor photocopy issues.
   / What belt is this ? #4
A really long one..... Sorry could not help it.....
This chart may help determine belt type... Length should be easy after that.... Probably half dozen sources for belt once you know specifics...
Dale
I have tried the C, the width is right, but the angles are wrong. The sides don't touch, only on the top. The 5VX seem the right shape, but would run deep in the pulley. The 8VX is to wide.
The length is something like 270 inch and it drives everything. That's why I want to be sure I get the right belt.
   / What belt is this ? #7
I've got a big book of belt specs and cross reference, there are a couple belts in the 272.2" OD and .875 TW range that might work. One has a cross section that resembles C above, and another that looks like the VX series. Look at a Dayco, Gates, Goodrich, Goodyear or Uniroyal C270 and see if it matches.
   / What belt is this ? #8
On something that old, you may be also dealing with worn pulleys. That might be why every belt profile you try does not match all profiles.
2005 FORD F-450XL SUPER DUTY DUMP TRUCK (A52707)
2005 FORD F-450XL...
Kubota M5-111 (A53317)
UNUSED FUTURE XLA59 - 59" DRUM SPIKE LAWN AERATOR (A52706)
UNUSED FUTURE...
More info coming soon! (A56859)
More info coming...
1996 Dorsey Enclosed Trailer, VIN # 1DTV11520TA252324 (A57453)
1996 Dorsey...
2017 Jacobsen Greens King IV Plus Reel Commercial Mower (A56857)
2017 Jacobsen...
