What ballast to use to total 1000 lbs
   / What ballast to use to total 1000 lbs #1
Carl Bert
Platinum Member
Rockland county, New York
Kubota B26, John deere X595
I am getting a 3PH ballast box which is just over 13 cubic feet and holds a total of 1000 lbs. My question is, what can I use to fill it that will weigh that much, or at least close to its weight capacity? I was thinking of wet sand, just not sure what 13 cubic feet of wet sand would weigh. Any suggestions would be appreciated.
   / What ballast to use to total 1000 lbs #2
The general consensus seems to be 125 to 130 lbs per cubic for wet sand. But of course it depends on the dry sand you start with. So 13 cubic feet X 125 =1625 lbs
James K0UA
   / What ballast to use to total 1000 lbs #3
Sand is roughly 90 to 120 lbs/cuft depending on the type
This site has density values for a variety of materials: Bulk Density and Specific Gravity Chart: S
Bottom line - Sand should meet your goal of 1,000 lbs with ease.
Wow, thanks guys. I was worried that I would have a hard time finding something to fill it with that would weigh the 1000 lbs that I needed. Obviously I was wrong. Thanks again
2017 HAMM H10i SMOOTH DRUM ROLLER (A52706)
2017 HAMM H10i...
2016 CATERPILLAR 336FL EXCAVATOR (A51246)
2016 CATERPILLAR...
2013 Ford Transit Connect Van (A52377)
2013 Ford Transit...
1993 Ford F700 Stakebody Flatbed Truck (A51692)
1993 Ford F700...
2017 FREIGHTLINER M2 BOX TRUCK (A52141)
2017 FREIGHTLINER...
