What ATV, side by side or UTV do you have.
   / What ATV, side by side or UTV do you have. #261
Like that John Deere!
Here's a pic of my Polaris Ranger 400.
   / What ATV, side by side or UTV do you have. #262
I have an '11 Gator 855D. Use it every day.
Jesse1.... far to clean. I have an 855D too....and it is filthy compared to yours.
Jesse1 or Roy Jackson....have either of you done anything for interior lightening? At night, you get in the gator, and since it doesn't have the instrument gauges, the dash is completely dark. I can locate the key instinctively, but I can't find the light switch. Somehow I need to get a low level light to come on.
   / What ATV, side by side or UTV do you have. #263
I haven't added an interior light yet.
Deere does have an interior light kit. I doubt I go that direction due to the cost. You can buy battery powered lights pretty cheaply, or you could use a 12v map light that plugs in to your 12v outlet. I have one of these...haven't used it yet (actually, just thought of it when typing this thread). In fact, I think I'll try that tomorrow.
   / What ATV, side by side or UTV do you have. #264
It was brand new in those pictures, hadn't even had it in the pasture yet. Not quite that clean now.
   / What ATV, side by side or UTV do you have. #265
The Kubota RTV 1100 out front. Need that a/c in Texas.
HS
   / What ATV, side by side or UTV do you have. #266
   / What ATV, side by side or UTV do you have. #267
I have the same machine...they are great!
Bought the work lamp kit (not installed yet though) and I'll want a windshield sooner or later
I can highly recommend a "ventilated" or "flip out" windshield. There are many after market companies that make them to fit any model UTV.
Closed.
Open, surprising how much air flows in.
   / What ATV, side by side or UTV do you have. #268
   / What ATV, side by side or UTV do you have. #270
As a follow up, I did try out the 12v Map Light.
Pic A is with the lamp off, pic B is with it on.
Now, the 12v outlet on the Gator dash is not switched, so if you leave it on when you shut your engine off, the light stays on (and could drain your battery after a while).
This is a cheap alternative (less then 10 bucks if you buy one). The one shown in the pictures was left here by the previous owners of our house.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
New/Unused CFG Industrial MX50R Mini Excavator (A57453)
New/Unused CFG...
Sterling 9500 (A56435)
New/Unused SD Lanch 12x20 Enclosed Carport (A57454)
New/Unused SD...
1998 FREIGHTLINER FL50 SPORT CHASSIS (A56129)
1998 FREIGHTLINER...
NEW Skid Steer Attachment Plate (A59000)
NEW Skid Steer...
