What attachments would you use for this job..
   / What attachments would you use for this job.. #11
Forgot to mention that if you are trying to level sod the only way is to bring in dirt. Sod requires cultivation and time to break it up.
   / What attachments would you use for this job.. #12
With everything you've done so far I would rent a skid steer with a harley rake. I don't see a tractor listed but they do make them for a 3 point hitch but you're less likely to find one to rent. It's the go to tool for most contractors around here.
Thanks guys. It's an interesting piece of land. Several acres of high land, then another few acres of marsh and then 1/2 acre of an island in between the main high land and the water. So there is a walkway we've built over the marsh to the island and the deep water dock is going off the other side of the island. The island section is going to be mainly grass, palm trees and live oaks. The area on the island is thin and long. The setback from the critical lines have to be at least 50 feet so I might can build a half-way house type thing but it will be very small. The house goes on the main high land. It was cleared last year and part of it has grass but the back half is dirt.
So in the attached photos you will see towards the mainland from the walkway between island and mainland. Then a reverse shot from the same spot towards the island. You'll also see the mainland where it is grassed up from the marsh towards well back on the mainland where a road is being put in, a pond dug and 20+ truck loads of fill waiting to be added to the road as needed.
Club Car Carryall 2 Electric Utility Cart (A55853)
Club Car Carryall...
2016 FORD TRANSIT T250 CARGO VAN (A57880)
2016 FORD TRANSIT...
33ft Dovetail Flatbed Trailer (A55315)
33ft Dovetail...
17307 (A55853)
17307 (A55853)
2024 FORD F250 SUPER DUTY BED (A57880)
2024 FORD F250...
2013 Ford Fusion SE Sedan (A56859)
2013 Ford Fusion...
