What attachment to Buy?
/ What attachment to Buy? #1
scesnick
Veteran Member
Garrett County Md. ( Western Md.)
Kubota MX5100
I have a horse pasture that needs re planted. It is pretty well packed and I know just throwing seed out on it will do next to nothing.
My question is what attachment will work best on this situation? ( other than a tiller) I have used my box blade with the scarifiers on my deer food plot with pretty good results but this pasture is much bigger. disk or plow? Any procedure advise would be appreciated also.
/ What attachment to Buy? #2
Every once in awhile I disk parts of my horse pasture to level out the ground. It does a pretty good job of breaking up the grass so I'm thinking if you made a couple/few passes everywhere that would do the job. A plow would probably leave pretty big chunks of dirt that would have to be broken up again. I'm on clay though. If you are on sand that may not be an issue.
/ What attachment to Buy? #3
Definitely Disk. Unless you want to plow and then disk.
3 days after a soaking rain is when you want to start.
!!!MY 1000th POST!!!! Pretty good considering I never took typing.
/ What attachment to Buy? #4
Well, if it's really packed you may need to run a sub-soiler to break it up before you disc. Just a thought...
jb
/ What attachment to Buy? #6
If you plow you will not be able to put livestock on the paster for some time. The grass roots will need time to grow deep in the soft plowed soil. I prefer to disc only. I set my weighted disc straight, disc the pasture, seed, light drag with chain linc and in a little time my horses are back on the pasture.
UNUSED INDUSTRIAS AMERICA HYD POST PULLER (A60430)
UNUSED INDUSTRIAS...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2020 CHEVROLET...
2020 Takeuchi TL8R2 Track Loader with 72in Tooth Bucket (A63689)
2020 Takeuchi...
2013 PETERBILT 367 MIDROOF SLEEPER (INOPERABLE) (A65643)
2013 PETERBILT 367...
2018 CATERPILLAR 326FL EXCAVATOR (A65053)
2018 CATERPILLAR...
New/Unused Mini Quick Attach Pallet Forks (A65583)
New/Unused Mini...
