What are these used for?
   / What are these used for? #1
russG
NH TC34
Enclosed is a picture of which the part i'm not sure of. I thought instead of welding hooks on the bucket I could bolt someing on these brackets.
   / What are these used for? #2
I was told a grapple attachment went in to them I put a long pin in my two for a chain or strap to hook to /forums/images/graemlins/cool.gif
Thats what I was thinking. thanks. If anyone knows what make grapple would fit on this bucket.
   / What are these used for? #4
Although I haven't done it yet, I was going to build a gooseneck ball hitch that I could install on these brackets for moving a trailer around. I've already got a grapple solution.
   / What are these used for? #5
</font><font color="blue" class="small">( Enclosed is a picture of which the part i'm not sure of. I thought instead of welding hooks on the bucket I could bolt someing on these brackets. )</font>
I have the same kind of bucket. I painted mine blue, but that doesnt matter. These brackets are used for the quick attach. The holes are cut off and the rest is used to weld on the receiver part. That's what mine looks like anyway...
   / What are these used for? #6
Osconda be sure to post a pic of that when you build it sounds like it would work mint for that. pivot a little and all /forums/images/graemlins/cool.gif
   / What are these used for? #7
Those look like the points on my grapple frame where a long 3/8 or 9/16 steel rod runs. The grapple pivots on the rod with the cylinder being anchored at a similar fixed point on the mounting frame.
   / What are these used for? #8
I don't think you want to stick anything in those holes with your current setup. I don't know what they're for, but I think you'll find that if you curl the bucket all the way up, those holes are actually behind the edge of the loader arm.
I did not even think of that I will have to look at it again. I would of found out the hard way.
thanks.
   / What are these used for? #10
A C shaped piece would be able to pivot over the bucket from there, but I don't know where you'd mount the anchor for the cylinder. Either way, you'll need to be adding something. They could work as anchor points, I think, depending on the layout of what you add. A grapple running on 3 cylinders would have some serious closing power.
PLEASE VIEW ALL PICTURES!! (A50775)
PLEASE VIEW ALL...
2008 KENWORTH T800 TRI-AXLE (A52472)
2008 KENWORTH T800...
2020 FOR TRANSIT CONECT CARGO VAN (A52577)
2020 FOR TRANSIT...
2007 Hino 268 Cab and Chassis Truck, VIN # 5PVNJ8JV672S50269 (A51572)
2007 Hino 268 Cab...
2010 Chevrolet Tahoe SUV (A50324)
2010 Chevrolet...
(9) 2 PLUG VALVES 1502 IRON (A52472)
(9) 2 PLUG VALVES...
