what are the effects of a plugged egr on a 6.0psd?
   / what are the effects of a plugged egr on a 6.0psd? #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
Pulled mine this weekend after getting new orings and gasket, my goodness.. Top port area was slam packed full!
Clean as a whistle now, but could not have been operating before
   / what are the effects of a plugged egr on a 6.0psd? #2
I run 7.3's... but 6.0's issues are egr/oil cooler related and seem to lead to head gasket failure. Hope you cought it in time, if your state's emission checks allow (ours do) I would recomend an egr delete and head studs, my wifes cousin did that to his before he sold the truck to my father in law. Big improvement... check out powerstroke.org 6.0 section for more details and better info. I can often be found in the 7.3 general forum area, same screen name.
   / what are the effects of a plugged egr on a 6.0psd? #3
My understanding is that the exhaust passage getting plugged is not as big of a deal as the coolant passage on the egr cooler. I am by far no expert (I don't even own one) but did a little bit of research on the subject when I was considering buying one. Hopefully this will get some discussion going.
   / what are the effects of a plugged egr on a 6.0psd? #4
From this thread: http://www.tractorbynet.com/forums/trailers-transportation/318815-6-0-power-stroke-questions.html
Ford designed the EGR coolant flow to go through the liquid/liquid oil cooler first, then to the EGR to cool incoming exhaust gases. The coolant side of the oil cooler has very small coolant passages that is prone to being plugged up. When this happens, coolant no longer flows through the oil or EGR cooler and the EGR cooler starts overheating and eventually fails, leaking coolant into the cylinders. Enough coolant leaks and you can then lift the heads leading to a headgasket failure.
So in addition to this poor EGR cooler design, Ford also uses their universal Gold coolant in the 6.0. This is a good coolant except not for diesel engines with EGR coolers since the Gold coolant has silicates in it. These silicates under high temps, precipitate out and, you guessed it, plug up the small oil cooler coolant passages. Now couple this with the fact that Ford designed the 6.0 heads with bolts (180ksi yield) instead of studs (220ksi yield) and you have a recipe for disaster.
Simple fixes for the above:
- Install a coolant filter - stat!
- Replace the Ford Gold coolant with CAT EC-1 spec'd ELC (or Ultra ELC) coolant. CAT EC-1 coolants have no silicates that will precipitate out under high temps.
- Install an aftermarket gauge that will allow you monitor coolant vs oil fluid temps. +15 degrees difference means you have a plugged oil cooler and an impending EGR cooler failure. Example is a Scangauge II that will monitor ECT and EOT.
Upgrades include installing an EGR delete kit and replacing the head bolts with studs (plus alternator and battery cable upgrades).
Once you do the above, the 6.0 is pretty bulletproof.
Those who say to "drive it like you stole it" are exactly right. These trucks need to be worked, not pansied around getting groceries.
Hope this helps.
I'm just trying to determine if the 'improved running condition' i'm experiencing is real or placebo. IE.. cleaning up a real dirty part then 'feeling' like it is running better. just not sure if something tangibly was fixed there.. or just feel good cleaning ;)
Woods 3pt 6ft Finish Mower (A49251)
Woods 3pt 6ft...
2016 Chrysler 200 Sedan (A46684)
2016 Chrysler 200...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A46684)
2013 Ford F-150...
TPM 18K Mini Excavator (A49251)
TPM 18K Mini...
10-16.5 Tires (set of 4) (A49251)
10-16.5 Tires (set...
2009 Hyundai Santa Fe SUV (A46684)
2009 Hyundai Santa...
