What are the ears called that cyl pins gothru
   / What are the ears called that cyl pins gothru #1
Stargazer
DSM IA USA 50310
Kubota Bx-23
Hi:
Thinking about adding hyd angle to rear back blade (landpride 60"). What are the ears that the cly pins go thru called? Source for? Don't have 1" stock nor bit big enough make hole. Thought pre made and bolt on/clamp.
Thanx PR
   / What are the ears called that cyl pins gothru #3
I think he's talking about the tang rather than the clevis?
   / What are the ears called that cyl pins gothru #4
   / What are the ears called that cyl pins gothru #5
He must be talking about the anchor end with a 1" hole and 1" thick.
   / What are the ears called that cyl pins gothru #6
Tabs, cyl mount, brackets, etc.
Hercules Sealing Products-Hydraulic cylinder repair seals and seal kits, replacement cylinders and cylinder components for construction and many other heavy equipment industries.
http://www.northerntool.com/shop/tools/product_620047_620047
http://www.peninsularcylinders.com/metrichydraulicaccessories.pdf
I have used a 3 in x 2 in tab, and bored a 3/4 or a 1 in hole for the pins.
If you use say 1/4 thick metal, you can bore the hole for a weld in bushing that will support the pin, or use say 3/8 to 1/2 in metal for the tabs/ears.
http://www.berrienbuggy.com/3099b8e0.jpg
I have also done a DXF drawing, and gave it to a place that did plasma cutting and had them cut about 20 of the tabs out of 3/8 steel.
Thanx JJ and all. The north tool link is what I am looking for guess also called tang. Least now got the term to look for.
PR
2017 Nissan NV200 Cargo Van (A53422)
2017 Nissan NV200...
2019 GEHL R105 WHEELED SKID STEER (A51242)
2019 GEHL R105...
JOHN DEERE TS 4X2 GATOR (A51406)
JOHN DEERE TS 4X2...
VERMEER NAVIGATOR S3 D10X15111 DRILL (A51406)
VERMEER NAVIGATOR...
2019 Allmand Bros Maxi-Lite 2V 15W S/A Towable Light Tower (A52377)
2019 Allmand Bros...
2022 JOHN DEERE 6120M LOT NUMBER 191 (A53084)
2022 JOHN DEERE...
