What are people doing for a good deck screw?
   / What are people doing for a good deck screw? #1
newbury
Super Star Member
From Vt, in Va, retiring to MS
Kubota's - B7610, M4700
   / What are people doing for a good deck screw? #3
I've used McFeely's stainless steel square drive screws for years on decks and many other things too. I recently did a rebuild of the Mendocino deck with about 4000 3 1/2" screws. Redwood deck boards into treated doug fir joists. Two of them broke running into thick knots, otherwise not a problem. I think the torx or spider drive is a better design, but the square drive has worked just fine for me for a long time. The dquare drive bits in local hardware stores are usually crap, they will strip your screws or break off. I get those from McFeeley or McMaster-Carr.
   / What are people doing for a good deck screw? #4
Anyone still use Grabber?
   / What are people doing for a good deck screw? #6
Deleted. I can't tell you what I did for a good deck screw years ago.....
hey hey Dudley... you are bringing back some happy memories. :drink:
   / What are people doing for a good deck screw? #7
I was holding my breath on that type.........
   / What are people doing for a good deck screw? #8
Home Depot and Deckmate really messed up with those screws. Worse things that I've ever used. They put little bits of meta in between the screw threads that caused the screws to strip out instead of grabbing and pulling. Lowes continued to carry the good ones that have not been modified to the new version. Home Depot doesn't have those bad screws anymore.
When I clicked on your link, it took me to the good screws.
   / What are people doing for a good deck screw? #9
I had to go with SS torx head screws. The coated ones were corroding.
Ralph
The important part of the link was in the reviews.
I hate having to return things and since I'm generally ordering on line I didn't want to order 5 or 10lbs of screws and then have to return them.
PORTER CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTER CABLE 150...
2021 Kubota SVL97-2HFC Compact Track Loader (A50657)
2021 Kubota...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A49461)
2021 Ver-Mac...
2014 Ford F-150 Ext. Cab Pickup Truck (A50323)
2014 Ford F-150...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A51039)
2016 Ford F550 4x4...
2011 V.E. ENTERPRISES 130 BBL STEEL VACUUM TANK TRAILER (A50854)
2011 V.E...
