What are people doing for a good deck screw?
   / What are people doing for a good deck screw? #1
newbury
Super Star Member
From Vt, in Va, retiring to MS
Kubota's - B7610, M4700
   / What are people doing for a good deck screw? #3
I've used McFeely's stainless steel square drive screws for years on decks and many other things too. I recently did a rebuild of the Mendocino deck with about 4000 3 1/2" screws. Redwood deck boards into treated doug fir joists. Two of them broke running into thick knots, otherwise not a problem. I think the torx or spider drive is a better design, but the square drive has worked just fine for me for a long time. The dquare drive bits in local hardware stores are usually crap, they will strip your screws or break off. I get those from McFeeley or McMaster-Carr.
   / What are people doing for a good deck screw? #4
Anyone still use Grabber?
   / What are people doing for a good deck screw? #6
Deleted. I can't tell you what I did for a good deck screw years ago.....
hey hey Dudley... you are bringing back some happy memories. :drink:
   / What are people doing for a good deck screw? #7
I was holding my breath on that type.........
   / What are people doing for a good deck screw? #8
Home Depot and Deckmate really messed up with those screws. Worse things that I've ever used. They put little bits of meta in between the screw threads that caused the screws to strip out instead of grabbing and pulling. Lowes continued to carry the good ones that have not been modified to the new version. Home Depot doesn't have those bad screws anymore.
When I clicked on your link, it took me to the good screws.
   / What are people doing for a good deck screw? #9
I had to go with SS torx head screws. The coated ones were corroding.
Ralph
The important part of the link was in the reviews.
I hate having to return things and since I'm generally ordering on line I didn't want to order 5 or 10lbs of screws and then have to return them.
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A51039)
Kubota BX2680...
Ford NAA Jubilee Tractor (A51039)
Ford NAA Jubilee...
Kenco PH9000 Self-Leveling Pipe Hook - 9,000 LB Capacity, 8FT Max Pipe Length (A51039)
Kenco PH9000...
2013 Freightliner M2 106 Water Truck (A50860)
2013 Freightliner...
2023 Ford F-150 4x4 Crew Cab Pickup Truck (A48081)
2023 Ford F-150...
(INOP) VOLVO L70H WHEEL LOADER (A50459)
(INOP) VOLVO L70H...
