Box Scraper What all can you do with a box blade?
   / What all can you do with a box blade? #1
dieselfuelonly
Chapel Hill, North Carolina
Yanmar YM1401D
Sorry if this doesn't belong here, but I did a search and not much came up...
Anyway, I am interested in what I could do with a smallish box blade for my tractor. I have a pasture that it looks like someone drove a large tractor/truck through the field at one point, and left some pretty good ruts in there, and I would like to smooth it out. Would a box blade be good for this kind of task?
I have tried just cutting the ruts down with my dirt scoop, but it is very time consuming since the dirt scoop fills up fast, not to mention it is very hard to get it digging into the hard ground.
Thanks!
Dennis
   / What all can you do with a box blade? #2
Yes, you can do what you list with a box blade. You probably will have to add weight to make it dig in if the soil is dry and hard.
jb
   / What all can you do with a box blade? #3
Get a box blade with scarifiers to break up the dirt. Also remember that softer dirt is easier to grade (add a bit of water) but you can't grade mud.
   / What all can you do with a box blade? #4
You list you have a tiller... since you don't own a box blade you could run the tiller over the ruts to break up everything then pull a drag over everything to smooth things out.
   / What all can you do with a box blade? #5
Run the tiller shallow enough to take out the ruts, but be careful about tilling too deep. You do not know what "surprises" await you :eek: and it could be an expensive discovery :(. You do not have to ask how I know this. You can then back drag the tilled area with your dirt scoop. Jay
2012 Ford F-150 Crew Cab Pickup Truck (A53422)
2012 Ford F-150...
2012 FREIGHTLINER M2 106 (A55745)
2012 FREIGHTLINER...
CAT 416B (A47477)
CAT 416B (A47477)
MINI EXCAVATOR BUCKET 24 (A55745)
MINI EXCAVATOR...
2018 HONDA RECON 250 4-WHEELER (A51247)
2018 HONDA RECON...
STAINLESS STEEL COUPLERS (A55745)
STAINLESS STEEL...
