What air tool/nozzle do you recommend for blowing out radiators/coolers?
   / What air tool/nozzle do you recommend for blowing out radiators/coolers? #1
erkme73
Middle TN
Mahindra 2555 HST Cab
Rather than blindly buying something I think might work from Amazon, I thought I'd ask the community - what do you guys use to blow air from the engine-side of the radiator to the outside? I'm assuming some kind of wand with a 90ー tip?
Looking to thoroughly clean all FOUR of the stacked coolers on my toy.
TIA!
   / What air tool/nozzle do you recommend for blowing out radiators/coolers? #2
My truck was overheating when pulling heavy loads.
I used a power washer from outside in and inside out as best as I could do it. No more overheating issues.
   / What air tool/nozzle do you recommend for blowing out radiators/coolers? #3
I have a couple of the old style long air blowers from my mechanicing days, just some 1/8" soft steel about 12" long without safety mechanisms. I slip a piece of rubber vacuum hose a few inches long on the tips so as not to stab the radiator accidentally. The tubing is easily bent by hand to whatever angle you want/need. I also have a HF long blowgun with the last few inches at a 45 angle and a conical rubber tip made on it that I rarely use.
   / What air tool/nozzle do you recommend for blowing out radiators/coolers? #4
I have a bunch. The usual ones are the plastic pistol grip with a six or so inch chrome tube, bent at the end.
Not sure that venturi style guns are better. I never used one.
I used compressed air for forty years to clean off equipment. I find myself more and more using my Makita 4 stroke leaf blower. I just prefer the larger volume of air and no hose to deal with.
   / What air tool/nozzle do you recommend for blowing out radiators/coolers? #5
There is a thread on TBN about a specific tool made to clean air filters, radiators, air conditioner condensers etc. Darned if I can remember the name of the tool. Standard lever operated air chuck with a wand of varying length with a series of small holes down one side of the wand. Lower the air pressure and blow out whatever is plugging your radiator, etc.
   / What air tool/nozzle do you recommend for blowing out radiators/coolers? #6
   / What air tool/nozzle do you recommend for blowing out radiators/coolers? #7
I've also stopped using an Air compressor in favor of a leaf blower. It's better for blowing debris off other parts of the tractor too. Compressor still there if I need to be more aggressive but so far the blower has handled it. I get mostly seed heads in the radiator from bush hogging
I've been using my leaf blower as well, but I can't get the end of it between the engine and the radiator block - at least not with any precision. That's where I thought directed air from a compressor might be more effective. Perhaps I'm over thinking it...
   / What air tool/nozzle do you recommend for blowing out radiators/coolers? #9
Not over thinking it at all, use the leaf blower to get the bulk loose stuff off, but then a wand from inside out to fully clean.
   / What air tool/nozzle do you recommend for blowing out radiators/coolers? #10
"That's where I thought directed air from a compressor might be more effective. "
I've been thinking about rigging a 3 foot or so garden hose on the end of my leaf blower - flexible to get between fan blades and concentrated blast of air.
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2012 Honda Accord Sedan (A50324)
2012 Honda Accord...
2014 Ford F-250 Service Truck (A50323)
2014 Ford F-250...
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
Club Car Electric Golf Cart (A50121)
Club Car Electric...
2003 Ford E-350 16ft Box Truck (A50323)
2003 Ford E-350...
