What air tool/nozzle do you recommend for blowing out radiators/coolers?
   / What air tool/nozzle do you recommend for blowing out radiators/coolers? #1
erkme73
Middle TN
Mahindra 2555 HST Cab
Rather than blindly buying something I think might work from Amazon, I thought I'd ask the community - what do you guys use to blow air from the engine-side of the radiator to the outside? I'm assuming some kind of wand with a 90ー tip?
Looking to thoroughly clean all FOUR of the stacked coolers on my toy.
TIA!
   / What air tool/nozzle do you recommend for blowing out radiators/coolers? #2
My truck was overheating when pulling heavy loads.
I used a power washer from outside in and inside out as best as I could do it. No more overheating issues.
   / What air tool/nozzle do you recommend for blowing out radiators/coolers? #3
I have a couple of the old style long air blowers from my mechanicing days, just some 1/8" soft steel about 12" long without safety mechanisms. I slip a piece of rubber vacuum hose a few inches long on the tips so as not to stab the radiator accidentally. The tubing is easily bent by hand to whatever angle you want/need. I also have a HF long blowgun with the last few inches at a 45 angle and a conical rubber tip made on it that I rarely use.
   / What air tool/nozzle do you recommend for blowing out radiators/coolers? #4
I have a bunch. The usual ones are the plastic pistol grip with a six or so inch chrome tube, bent at the end.
Not sure that venturi style guns are better. I never used one.
I used compressed air for forty years to clean off equipment. I find myself more and more using my Makita 4 stroke leaf blower. I just prefer the larger volume of air and no hose to deal with.
   / What air tool/nozzle do you recommend for blowing out radiators/coolers? #5
There is a thread on TBN about a specific tool made to clean air filters, radiators, air conditioner condensers etc. Darned if I can remember the name of the tool. Standard lever operated air chuck with a wand of varying length with a series of small holes down one side of the wand. Lower the air pressure and blow out whatever is plugging your radiator, etc.
   / What air tool/nozzle do you recommend for blowing out radiators/coolers? #6
   / What air tool/nozzle do you recommend for blowing out radiators/coolers? #7
I've also stopped using an Air compressor in favor of a leaf blower. It's better for blowing debris off other parts of the tractor too. Compressor still there if I need to be more aggressive but so far the blower has handled it. I get mostly seed heads in the radiator from bush hogging
I've been using my leaf blower as well, but I can't get the end of it between the engine and the radiator block - at least not with any precision. That's where I thought directed air from a compressor might be more effective. Perhaps I'm over thinking it...
   / What air tool/nozzle do you recommend for blowing out radiators/coolers? #9
Not over thinking it at all, use the leaf blower to get the bulk loose stuff off, but then a wand from inside out to fully clean.
   / What air tool/nozzle do you recommend for blowing out radiators/coolers? #10
"That's where I thought directed air from a compressor might be more effective. "
I've been thinking about rigging a 3 foot or so garden hose on the end of my leaf blower - flexible to get between fan blades and concentrated blast of air.
Landoll Hauloll (A51039)
Landoll Hauloll...
2002 International 9200i Truck (A51039)
2002 International...
2017 Claas Jaguar 860 Forage Harvester (A51039)
2017 Claas Jaguar...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
1998 Dorsey Trailer, VIN # 1DTP16K29WG052604 (A48836)
1998 Dorsey...
2017 F-550 Bucket Truck (A51039)
2017 F-550 Bucket...
